16Hz @ 105dB in 6 Liters !
I discovered this for the first time yesterday , whilst looking for something totally unrelated to audio !
Devialet Phantom
Uncover the richness of songs you have heard a thousand times in all their amplitude, from sub bass at 16hz to ultra sharp sound at 25kHz with no background noise, no saturation, no distortion, all that up to 3000 Watts and 105 Decibels of power.
Phantom
Download the White-Paper-Phantom-en.pdf 😉
Review here Review: Devialet Phantom | WIRED
I ignored all the airy fairy etc talk in the above, instead concentrated on the Bass Tech.
It appears they have acheived something remarkable, in such a compact device. Amongst other things, it operates in PP Push-Push to cancel out vibrations & movement. It also seems to incorporate a type of AceBass feature.
Simming this would be interesting, to say the least 🙂
105 dB is as loud as a rock concert!
16Hz at a deafening 82dB!
The aluminum casting holds a lot of air pressure!
3000 watts! Three-THOUSAND watts!
It took 30 MILLION dollars to design!
You CAN'T hear below 20Hz!
I do find it amazing that they use parametric EQ though... that is why it took them 4 years.
Amazing...
If I'd like to get stereo using two of these at my place and play at volumes I usually listen to my soundsystem I would have to change electrical wiring in my house. 10A fusing per unit means 2300W of max power consumption per unit. Pretty awesome.
NOT.
