vinyl coefficient of friction
Indeed, seems Barney Oliver's was in the public domain in the 1970s.
About 4 years back I came up with what I thought was a neat topology for a true transimpedance phono input stage, including how to solve the awkward incorrect filter pole with arises from the natural LR of the cartridge. Only to find this in the search, from 1982, which already discloses it:
So much for prior art. I suspect any phono stage that had to be user tweaked for each cartridge would have limited commercial appeal.
Now you have me wondering about straight into a transimpedance mode amp with digital de-emphasis. :scratch1: Inject a little inverse RIAA and compute a matched filter. Don't quite see what you gain with MC, maybe we can restart the mechanical damping from the motor assembly discussion.🙄
azimuth you normally set with an L-R null. If you put in a mono impulse and digitise you 'might' be able to calculate how far out it is with one shot.
Antiskate was TBH a mad guess without thinking, but sure there is something that could be inferred.
Digital or analog, the same job is there to be done........it relaxes requirements on the 1st stage if one isn't trying to squeeze a bit of compensation out of it at the same time though, either way.
Just thinking about the dynamic headroom issues. BTW, in looking up stylus wear photos for someone else I came across a thread where someone detected stylus wear by an increase in crackle when a fresh cart is quiet on the same record.
if you can get a suitable test record. Or MEMs vibration stand to wiggle the needle.
'There's a hole in my bucket'...
High Frequency Testing of Gramophone Cartridges using an Accelerometer
http://www.bksv.com/doc/TechnicalReview1976-2.pdf
Please note the discrepancy btn the test record curve and the accelerometer curve at HF, due to vinyl-grove compliance/tip mass interaction.
The test record curve is a system response, the accelerometer curve is a component response.
See also this:
Calibration and Standards. Vibration and Shock Measurements
http://www.bksv.com/doc/TechnicalReview1981-4.pdf
George
That sort of makes it useless in this application, though in general these graphs cast a shadow on worrying over +-.1db RIAA.
I believe a few of us do something similar. When I set up a phono cart I digitize and look hard at the results for a lot of things, azimuth being one of them. Test records and mono pressings are helpful.
