The diyAudio Firstwatt F6
Well the project is on hold; wanted to order the PCB + transformer but that was already sold out before I woke up (took somewhat longer than blinking,. . )
Anyway - yes I have closely matched K55's. (four pairs).
And I have the matched FETs.
And I have the chassis from my F5.
Jensen is unobtainium in Europe.
What Lundahl transformer is advised?
Bare - With 200W SMPS, you will probably need to use one per channel, that's a bit small to run the entire amp.
Thank you .. Was intending Dual mono.
Whilst Dithering the last few boards/txs sold out.
No matter ..I can wait, as if there was choice 😉
Questions; What were those alternate 'cheaper' tx's that Nelson suggested wayyy so many posts past (and I can't relocate)
What's the purpose of buying Matched Jfets then.. If any?
No one has considered relocating their Torroids to a seperate Box(s)??
I've got a pair of CineMag on my Tea-Bag F6. Great transformer! 😀 😀 😀
The diyAudio store boards will be made for the Jensen. (I'm already talking to them...)
Do you have a Model # for those Cinemag transformers (post #228)
OK found it:
CineMag cmoq-4hpc (which is pcb mount/ special order, Leads version is in stock)
No idea on pricings.. yet.
Considering a point to point build of this rascal... clever or not.
Easier than waiting 🙂
Hmm.. dual outboard..Smps's (or PSU's for that matter) allows for an inexpensive Bespoke Box of markedly smaller volume, with 'pretty' Folded Copper Sheet heatsinks,
lotsa imaginary notions.
Order PCB+ Jensen when they return to the store. The PCB only fits Jensen.
There will be 60 more PCB+Jensen kits to the store in about 2 weeks. And then that's it for awhile, until PCB production arrives, in 6-8 weeks.
boys , 100mW part will work perfectly fine
little analysis can't harm
current through it is here : (Urail - Uzenner)/10K
so , say , 14V/10K=1.4mA , resulting in bloody 1.4mAx9V1=12.74mW of dissipation
that's what one can call power de-rating factor :clown:
all that according to schm in attached file , or schm in post #1 on this very thread
boys , 100mW part will work perfectly fine resulting in bloody 1.4mAx9V1=12.74mW of dissipation
Remember that Zener diodes are noisy and less stable if operated at too low a bias current. You need at least
around 5% or more of the maximum current (Pd max/Vz) to begin to get away from those problems.
A 400mW diode may not work as well for this purpose as the 100mW diode.
Most of the ones I see at Mouser are rated at 1W.
So 1 Watters are going to be noisy?
