Have you discovered a digital source, that satisfies you, as much as your Turntable?
What is your amplifier? Have you done similar blind test with $3 "digital" amplifier from ebay?
Actually, no. I suspect a cheap amp would be just fine. My current amps are an exceedingly old Sony 3200f running my subs, and an original Phase Linear 700 running my KEF r101s. Back when I owned an audio store, I was never actually able to hear amplifier differences, so I don't worry about amps.
Chalk it up to too may top-down rides in the old Alfa, or too many years in the orchestra when I was young... Yes,we were a high-end shop, carried Audio Research, Crown, Mac, etc.
Actually I was worried you did blind test your expensive amps with some ebay $3 digital amp and found no sound difference...
Lightweight class-D amps are so practical. You can then secretly have them and sell the expensive ones to the audiophools.
I don't know whether in hi-end audio shop you developed some kind of knowledge that certain amps are fine for long time listening and some others are quickly boring or fatiguing. Or may be only audiophools have that knowledge 😀
And tell me now precisely what this has to do with " one element has a brilliant set of numbers, from one set of technical tests, then it is now 'transparent' "
I never referenced any set of numbers from a technical test, and did not claim anything to be transparent.
Try again. Tell me just how I fit into the mold of how you imagine an objectivist thinks
The concept of "bit perfect" is the "brilliance" - that it transcends everything else ...
What I do know is that the less interaction, the less bit mangling, that software does to a stream of digital audio, the better. I also know that software bit mangling has far greater potential to degrade audio reproduction than the miniscule (if at all) variations in signal noise inside a PC due to the use of one player as opposed to a different one
And how do you know that?
Frank, you can go on and on trying various players and clicking random features on and off again, but until you take steps to ensure that the players are not mangling the bits, the miniscule possibility of different PC "noise patterns" from one player to another remains completely irrelevant.
Some of the options I vary I think I can be quite certain don't "alter the bits" - such as, adjusting delays, in no. msecs.
You won't believe me, of course, or agree, but the difference you are claiming to hear is almost certainly directly due to the fact that the bitstreams from the files are not making it to the audio chip unscathed. Data integrity is not being maintained.
Data integrity has nothing to do with it - the qualities I chase are revealed in low bit MP3, decoded before use; and, obscured in the very best hi res files, with a poor setup.
Once this issue is worked out between the OS and player(s), then perhaps it may be worth it to pursue your noise pattern theory. I do suggest investing in some very sensive equipment to put that theory to the test..
I have that already - it's called "ears" ... this is objectivist thinking at its very best - unless a machine can be made to come with some numbers a phenomenon can't possibly be real - the possibility that a) something is, and b) no readily accessible, easy to use means are at hand to "measure" the "is'ness" - does ... not ... compute ...
abraxalito said:
False dichotomy - what's the product of the bias is just as real.
BigE said:
No. Delusions may seem real, but they are still delusions.
I once read about a "test" where a switch was installed and marked with two positions: SS and Tube. Two amps were visible, a SS amp and a tube amp. Only the SS amp was functional, although the heaters did glow in the tube amp.
When people switched from SS to tube, and back, they commented how sterile the sound was when switched to SS, and how warm it was in tube mode.
Clear about what is real here? If not, it is that the switch was a dummy, and had no effect. Only the SS amp was driving the speakers.
No. The goal is zero, I repeat, zero colouring.
I agree.
Digital is harder, most times, to lift to the required level, LP is easier - hence the preference by many for the LP.
That's where I disagree. It's much easier for a digital source to do precision reproduction. Why else would playing a recording of vinyl playback trough a digital source sound exactly like the actual vinyl playback?
It suggests that the colouring from vinyl playback enhances the perceived "quality" of the sound, despite the fact that the precision of the reproduction is not optimal. If colouring is not a part of the equation, then the "quality" of LP becomes completely imaginary.
I'm fine with that conclusion, but I know that it will make most vinyl lovers red hot furious, so I'm trying to come up with a more diplomatic explanation.
Frank;
Did you listen to these:
http://www.diyaudio.com/forums/everything-else/273330-low-level-detail-experimental-search-test-2.html#post4298626
As of this posting the files appear to have only 2 views. I know that I downloaded them. Listening to the two tracks small differences are only audible when low level mixed in track is peaking. This is with only -30dB attenuation of the mixed in track.
In the above thread the bit mangling is intense, yet the audible difference is small, very small.
Only way to verify bit perfect playback is with soundcard with digital I/O that lets you capture same data that the DAC receives.
Ears alone will never suffice in confirming bit perfect playback.
I've gotten bit perfect playback from Windows MP, Audacity, Cool Edit, JRiver Media, Foobar, and other software as well.
Confirming interference from computer, display, and power supplies and relative levels is easy. Ears work well for this in conjunction with measured output from DAC.
If I where you I would cancel my internet service and save the money until I could purchase a soundcard that has mic preamp, and digital I/O that supports loopback.
How does accurate digitization and reproduction of vinyl say anything about vinyl playback? That's l like saying photographs of a farm tractor says something about farming.
So you are suggesting that the "quality" of an LP is defined by distortion... what if the mastering on the LP is superior to the mastering of a similar CD?
I suspect that is applicable to those die-hard vinyl fanatics that cannot accept any sort of digitization in their systems.
"Bit-perfect" is not a concept. It is a term used to describe a very real situation in which the bit stream of ones and zeroes is retrieved from a file and delivered to a DAC or sound card in such a way that integrity of data is maintained.
Furthermore, I have never said it transcends everything else. In fact I specifically said "it is not the Alpha and Omega". It is simply one part of the puzzle. Without it, all bets are off.
I know this because I have done the testing. One type of bit mangling that is commonplace is sample rate conversion (SRC). All mainstream operating systems do it by default, and they generally do a pathetic job of it by default (in the name of efficiency). The result is often obvious degradation of the audio. If one does not specifically address this issue and take some simple steps to avoid it, the result will very likely be "digitalitis". Stack digital volume control, digital EQ, and any other "enhancements" on top of the SRC and the "digitalitis" is exacerbated. People with average ears can hear this. I have confirmed it.
I have also tested your "noise pattern" hypothesis and described it earlier in the thread. Apparently, you did not understand me. Ultimately, I listened to my system under dramatically different load conditions. The "noise patterns" inside the PC due to extremely different CPU, cache, and RAM utilization during my testing would be orders of magnitude greater than the difference in "noise patterns" inside the PC due to using one software player rather than another. During my testing, there was absolutely no audible effect of dramatically higher system activity. The test was repeated with 3 different software players (all configured for bit perfect output) and the results never changed.
These tests show that bit mangling has far more potential to degrade sound quality than the miniscule differences in system activity from one software player to another, because an average listener can hear the most commonplace bit mangling, whereas experienced listeners cannot hear the effects of "noise patterns" caused by dramatically different system loads, much less very subtle differences caused by different players.
If this logic does not compute for you, then I have one emotion left; pity.
Have you confirmed that the bits are not altered by that feature, or are you making an assumption?
Without data integrity, you are left with a facsimile. Often the facsimile is of considerably lower quality and it is polluted with audible artifacts. To get a visual representation of how different SRC algorithms perform (for example), look here SRC Comparisons By default, the site shows Ableton Live 9.11 vs. Acon Digital. You can use the drop-down menus to select from a huge variety of SRCs. The cleaner the sweep, the more "perfectly" the SRC is performing. If you take some time to look at various SRC performance, you will quickly realize that some perform vastly better than others, and that many of the "usual suspects" do not perform very well at all. Apple apparently realized this somewhere between Tiger and Leopard.
The point here is to illustrate why attention should be paid to if and how SRC is applied in your digital chain. One solution is to ensure that the SRC algorithm is of very high quality (and devote appropriate CPU resources). A simpler and more effective approach is to ensure that SRC does not occur at all. It is trivial to do so.
SRC is merely one form of bit mangling to be avoided (or at least optimized).
OK Frank.
OK.
It says that whatever qualities are present in vinyl playback are accurately conveyed by digital reproduction. This means as a minimum that digital reproduction is at least not inferior to vinyl in terms of sound reproduction.
The converse test (taking a digital source and reproducing it via cutting and playing an LP) would be interesting. I suspect that it would be fairly easy to distinguish the difference between digital and digital-cut-play. Even if some prefer the latter, this would confirm that vinyl is inferior to digital for sound reproduction.
Mastering quality is irrelevant to the innate quality of the medium. The question is simply this: which is better at reproducing a pair of music voltage signals, vinyl or digital?
