Dac Audiophonics WM8741+ WM8805 modification !!
Hello everyone,
I pcb DAC audiophonics dac8741 - dac/controleur de volume wm8805 + wm8741 in this subject, I'm going to improve the power supply section by replacing capacitors + diode rectifiers and replace capacitors on signal .It features a crystal oscillator XTAL osc NSK 12.0000 MKZ, do you even replacing this oscillator with another best will have benefits on sound? which put in place of it?
ok, considering that the first question had no effect .... let's try another question;
this dac has an unbalanced and a balanced output .I only use the unbalanced output, if I wanted to replace the OPA (four) present, I have to replace all four or just replace the two near unbalanced output?
Hello guys ,
other questions DAC ;
it has a ;
Dip Switch :
SW1 : Anti clipping ( de 0 à - 2dB ) en entrée
SW2 : The brightness of the bill-poster ( min / max )
SW3 : upsampling 128x / 256x
SW4 : not utilisé
What is the SW1 and SW3 ?
another question ; do you think that output impedance ?
Thank you🙂
