JFETs from Linear Systems
What about last hot news from DiyAudio Store ?
Best regards
Unhappy customer!
Hi All,
I have been patiently waiting for some time for the fets to come back into stock and have been checking the website everyday. Today I log on to find that the store is out of stock already not more than 12 hours after they have gone on sale!
How long before we can get some more?:(
Tony
There is an overlap on grades where a B grade could be as much as 12 idss and a C grade is 10 idss. I hope that is the case. Three of my fets are C grade and one 170 does not have a grade. I am going to check the idss later today and I will report my findings.
David
I am happy to report my findings testing the idss for the matched jfets.
The first pair
k170 10.6 idss
j74 10.59 idss
2nd pair
k170 10.6 idss
j74 10.57 idss
I was using a 9 volt battery that tested 9.6 volts. I am very satisfied with the results and how well both pairs matched to each other. Hats off to the Diyaudio store.
David
Switches things on and off again
Joined 2000
Hi All,
Tony
Very sorry Tony, and yes, they sold out within 12 hours. If we emailed everybody (eg the whole store list) they would sell out before the email queue had finished sending. Currently, staying tuned to this thread you are reading is the best chance you will get. It's a difficult situation, and we are going to try to find a fairer way to distribute these as fairly as possible in the future.
@ Diyers
Grade letter on matched LSK pairs is C not B :scratch: ?
Best regards
David
Some of the JFETs have the letter C on them, and some are unmarked. The marking of C on the transistor is not a grade marking. The grade is unmarked. Really. We have double triple confirmed with LS, who supply us the different grades in separate packaging and we are very careful to ensure we don't mix them up. The C on them has nothing to do with the grade, the grade is not marked. You just have to trust us :)
Experience with grade D jfets
I recently ordered 8 each of the LSK170D and LSJ74D (grade-D) jfets. Here are the measured Idss and transconductance values for these fets. It should be noted that none of the LSK170 jfets had an Idss above 18ma which is the low end of the grade-D range, but all of the LSJ74 jfets had Idss within the grade-D range. Also note that LSJ74 74 was defective, with an unusually low transconductance value.
part# Idss(ma) gm(mS)
LSJ74D 70 19.22 36.20
LSJ74D 73 19.60 34.80
LSJ74D 72 20.32 34.80
LSJ74D 76 20.70 35.70
LSJ74D 74 20.82 13.10
LSJ74D 75 21.06 34.50
LSJ74D 71 21.66 35.20
LSJ74D 77 21.90 35.20
LSK170D 60 12.30 32.50
LSK170D 62 12.60 33.00
LSK170D 61 13.12 33.00
LSK170D 63 14.58 33.30
LSK170D 65 15.54 33.60
LSK170D 67 15.90 33.20
LSK170D 64 16.60 33.10
LSK170D 66 16.62 33.30
Administrator
Joined 2010
Hello lhquam,
Please email the Helpdesk with your shipping details so we can send you replacements as well as send you a return shipping label for the defective JFETs so we can have LS look into these. Thanks.
