http://forum.nasaspaceflight.com/index.php?topic=37642.0
This is what I am trying to read these days...not really trying to get it, just a bit of excercise to those two lazy brain cells 🙂
P.s. there is some Diy effort going on too. Someone over here may want to try this. Just beware of microwaved balls! 🙂
http://www.masinaelectrica.com/emdrive-independent-test/
This thread does an average of 8 posts a day, odds look favorable that you'll be hitting 25000 yourself before this thread count does.
I'll let the numbers speak for themselves jacco..... 😀😀😀
6000 posts divided by 8 is 750 days.
You turn 25000 days in less (49 for the 19.5th time)
(it means you're a troll, each of your posts requires multiple responses)
Hey Zennie!, your Modness..
This is off-topic for an off-topic thread , so it's OK, and all are welcome to kibbitz!
Could you opine as to which of these Grades (A,B,C,D ) of these two Linear Systems JFETS are most appropriate for different ( mostly Pass ) amps?
We're already matching some grades but I want this to be a double-blind question 😉 so I won't say which..
Is it better to break it down for different amps, or are Pass amps pretty consistent in their requirements?
Spec sheets enclosed...
Yer
Ten hup!
Yer
Ten hup!
for both genders , it seems as :
B is same as Toshiba BLue
C is same as Toshiba Violet
D is sort of Toshiba Violet on steroids
it's still best to make differentiation between B and D by type of circuit where used
Papamps are pretty consistent regarding JFet categorization , loosely divided in two camps:
I - if circuit is having self biased JFets ( via source resistance ) , use B grade , where Idss of 8-10mA is preferred , as most universal ....... thinking in both current and dissipation terms
II - if circuit is having "externally" biased JFets ( Aleph J as example , with CCS governing input LTP current) , you can freely use C grade or even D , without ill effects
fact is - when messing with JFets , one need to know at least something about life and everything and 42 .......... and you boy's can't cover for that
edit: I still don't know anything about life , anything about everything ...... and I'm at number 3
Here iz a photo of a hot Redneck Woman for ya Jacco..... I figure that it should keep you busy for at least the rest of the day..... 😀😀😀
desktop for kinky users
I would settle for a rubber keyboard
(also easier to clean)
For all of you who use DIYaudio whilst at work!
Viewpoint: Why do people waste so much time at the office? - BBC News
at the office?
Bit hard to tell if someone's dead at the office, asleep, or snorting coke from the table top (in the United Cocainedom)
Finished work at 19:00
another 72 hours week...
Tomorrow can have lay in before new job interview
and then 4 nights in a row
Hope that you get it...........that is if you want it.
Tanks dudes
Yup using intraweb on my lunch break at work first night of 4
will let you know when I know
If I did that then nobody would ever know anything..... Hell - I don't even know when I didn't know it!!! 🙄
Was it not one of your neighbours that said?
There are things that we know that we don't know and used it as excuse to end up in the history books.
Did he ended up in Guinness world record book for lowest IQ ever or is that prize still unclaimed?
Beat the hell out of other ones that where certain that they do know
It wuz lowest number of functional brain cells - runs in the family..... 😀😀😀
- The Pass Pub: The High-End Off Topic Thread
