wiring 5 amp to single stereo input
hi i want to build an amplifier for high pass, mid, and subwoofer for single input stereo. should i use preamp? if yes it should be 2 preamps right? or more?
how i wire the amp to the preamp? should i parallel it? like in the right preamp, i have juction that go to each amp (go to filter first then amp)? or i have 3 preamp for each section? if so am i should wire the stereo input from computer to be parallel or there is another way?.
i've search on google but i cannot find the "correct" instruction on google the exact tutorial. thanks
Regard, Aji
First lesson : the "one" contains "the two"
as in one plug, classic mini head phone type mini-jack, there are three
contacts, one is common ground (sleeve) and the two are left (tip) channel and the right channel is the [ring of the plug]
Phone connector (audio) - Wikipedia, the free encyclopedia
In a 2 channel and 1 subwoofer system, namely 2.1, after the plug the two channels get summed ( mixed) in one channel, then with the aid of electronics, the signal get low frequency- passed ( processed ).
Same process happens to any speaker since those are going to be incorporated into a system, when the design asks for this 😱:Olympic:
the "phone connector" is a corruption of telephone from way back.
It is commonly known as TRS now, trs stands for tip, ring, sleeve.
it comes in three common sizes. 2.5mm, 3.5mm and ¼"
But it has a big drawback. During insertion and removal, some of the poles short together
This is not a problem for a passive source, like a microphone. This could destroy an active output stage.
A three pin plug and socket is better. vhs, keyboard and mouse have a small multipin plug and socket, DIN have a bigger 3pin plug and socket
XLR are available in standard size, getting very big and a smaller size, still a bit big.
ESP has a few very good articles on active systems and bi-amping.
It seems you're talking about running 3 separate amps, one amp for tweeters, one amp for midrange, and one amp for bass.
Then you're talking about 3 entirely separate systems, the only common factor being the input. The sequence would be:
Highs: audio source ~> high pass filter ~> preamp ~> amp ~> tweeter(s)
Mids: same audio source ~> band pass filter ~> preamp ~> amp ~> midrange(s)
Lows: same audio source ~> low pass filter ~> preamp ~> amp ~> woofer(s)
All of which is a pretty complicated setup. Unless you're running pretty expensive speakers I question whether you'll get a return on your effort and expense. You might be better off with a simpler, single 20-watt amp. You might be interested in the "Typical Applications" circuit on page 2 of the LM1875 data sheet, which is here: http://www.ti.com/lit/gpn/lm1875
Also I'm posting the below illustration, which might be of interest.
Explanation:
In audio the ruling concept is "line level." It rules in the sense that preamps, mixers, and similar are expected to have a line level output, and amplifiers develop their full rated wattage with a line level input.
Unfortunately, in these multinational times there are several definitions of line level. However, you won't go far wrong by using the classic definition of line level = nominal one volt.
"Nominal" means approximately. Line level has to be an approximate figure because audio voltages actually vary all the time, to produce very soft or very loud audio at the speakers or headphones. But there has to be some kind of planning figure, and "line level" is it.
It's worth noting that usually headphone jacks work at about line level. Nearly always headphone jacks can be used as line-out jacks, which connect to line-in jacks.
It's also worth noting that audio sources such as CD players, Blu-Ray players, TV sets and similar usually have an output voltage close to line level, and don't need a preamp before they're connected to an amplifier. But the only way to be certain of this is to look at the manufacture's specs, or to just connect the device and see how well it works.
Because most audio sources output something close to line level, preamps and mixers usually don't have much gain. They might have a gain of around 5 (14 dB), intended to just bring various unknown inputs up to the required line level output to run the amplifier or other devices.
(Amplifiers might have a gain of around 20, which is about 26 dB.)
Han,
Bi-amp means two quite different topologies.
In the UK, at least, Bi-amping means to use TWO amplifiers to drive the TWO sets of terminals on the back of a two way crossover type speaker.
In the US, bi-amping is used to mean "active speakers". where two amplifiers are preceded with a pair of filters and the two, filtered and amplified, outputs are fed to separate (no crossover) low frequency and high frequency drivers.
2.1 has nothing to do with bi-amping in either of it's forms.
2.1 is two separate audio channels (stereo) with a shared (mono) part frequency range channel for the bass only, i.e. it is three channels of audio.
If you want to use three amplifiers to drive three different frequency drivers, then you are proposing an active speaker system. That will give you ONE channel of Audio. If you need stereo you will need six amplifiers for the six speaker drivers.
Do some research and make sure you understand what you are proposing.
Then you can ask about how you get audio signals into your active speaker system.
really odd.
here bi-amping means 2 amplifier drives the same speaker (they are in parallel)
bi-wiring with 2 amplifiers is when every apmlifier drives a speaker, with a passive crossover inn between.
active multi-way is when the crossover is infront of the power amplifier, and the filters are not made out of passive elements, active crossover multiway is when the corssover is an active one .
2.1 has some variations too.
it can be a stereo amp driving 2 speakers + a subwoofer (commonly referd as tri-wireing in autmotive stuff here)
it can be with a stereo amp and a dedicated sub amp driving speakers, with all of them having passive crossover in between the amplifier and speakers, and active one, and aactive xover one, and even just a single stereo amp driving a pair of fullrangers and in parallel a single dual voicecoil sub/bass driver with 2 crossovers.
i think those are all the versions.
i don't think there is a universal standard...
so, ive been reading the article about "bi-wiring" and stuff. its kinda not worth to make? cause now i'm using my own full range speaker, which isn't good at bass neither the high freq so im planning to build another for bass and other one is for tweeter
for tweeter should i use another amp? or just crossover from the already build system?
regard, Aji
...for tweeter should i use another amp? or just crossover from the already build system?
The whole point of biamping is that one amp drives the tweeters, another amp drives the woofers. The two separate amps don't feed each other in any way, and there are no crossovers.
There are no crossovers, but there are filters. The high frequency amp is driven through a high-pass filter, the low frequency amp is driven through a low-pass filter.
The image below might clarify. It's only one possible arrangement, others will work just as well. Values shown are representative, actual values would be matched to your needs.
This calculator might be of interest: http://www.muzique.com/schem/filter.htm
Now I'm using my own full range speaker, which isn't good at bass neither the high freq. So I'm planning to build another for bass and other one is for tweeter
For tweeter should i use another amp? or just crossover from the already build system?
A biamp system is not simple. If the two (or more) amps are not balanced to work together then the system will never sound right, and this balancing is difficult.
You'd probably be much better off to continue using the amp you have, and use a standard crossover network between your tweeter and woofer.
Exactly what kind of crossover network is required depends on the speakers you buy, and this information should be provided by the speaker manufacturer. NOTE: if the manufacturer or retailer can't supply this information then you're looking in the wrong place, buy elsewhere.
You need to consider
Active or passive crossover, if active then you need a three way active crossover circuit like...Linkwitz-Riley Electronic Crossover
Gajanan Phadte
well i guess it'll be interesting if i'm using active crossover since it much easier to tweak? or just the opposite?
what do you mean by "not balance"? im guessing the power that delivered between each section (sub/woofer/tweeter) is not the same? or each amp?, if each section, can i fine tune it with pot in the crossover to tweak the way i like it?
unfortunately most of the seller in here dont know the exact information i might need. they just know how big it is and how much are the impedance
[in biamping] what do you mean by "not balance"? im guessing the power that delivered between each section (sub/woofer/tweeter) is not the same? or each amp?, if each section, can i fine tune it with pot in the crossover to tweak the way i like it?
What pot? What crossover?
[in biamping] one amp drives the tweeters, another amp drives the woofers. The two separate amps don't feed each other in any way, and there are no crossovers.
Did you look at the diagram in post #14? Every box is a variable, so are the speakers, and all of these variables must be balanced to work together. This is not going to be accomplished with some small final adjustments, some "tweaking." The system must be designed as a balanced whole--including the speakers--from the beginning.
As I said in post #5, running multiple amplifiers is complicated and, in my opinion, of debatable benefit. It seems to me you'd be far better off running one amplifier that drives woofers and tweeters through a crossover network--as in my next post.
When a single amp drives woofers and tweeters through a crossover network, it's not just "a" crossover network. You can't just hook two random speakers together with some equally random crossover network and expect good results.
Or...yes, I guess you can. People do it all the time. But enough about that.
Tweeters have a given frequency response. So do woofers, likewise mids. It's necessary to buy one with respect to the other(s), so their frequency response overlaps.
Then the crossover network controls which frequencies are sent to which speakers. So clearly the crossover network must be in balance with the speakers, since that's the whole point in the first place.
The critical item is the frequency response of each speaker. If the retailer can't supply this, then look it up online. If the information can't be found online, then it's impossible to balance the crossover network with the speakers.
In which case, well, you hook up some random crossover network and hope for the best. What else can you do?
For every 100 people swearing that active crossovers are better, there are 100 people swearing that passive crossovers are better. In electronics and audio there is no "best," there's only as close as you could get under the circumstances. PS: simpler is always better.
