They're slightly different judging from the pictures. I would just get them straight from Sure. I find it weird that the description on Parts-Express is better than the one from Sure....
I don't get why the first search for the Sure TK2050 is parts-express and not their own website..
Has anybody here measured what the output is in normal/sunny weather with solar panels vs the claimed output (peak)?
I haven´t measured. But optimistically you are only going to get half of the rated output.
First: You loose A LOT of output just by angling the panel incorrectly. IE not directly at the sun.
Second: the slightest bit of shade kills the output by a lot.
How are the vibrations reduced from the boominator or designs based on the boominator? The enclosure could be covered in a carpet type sheath or is this unnecessary?
Is this for amorphous panels?
@JDpaul88 I just discovered that the one on sures website isn't a TK2050 but a TDA7498
By design almost all vibrations are completely eliminated.
@lutkeveld - Thank you; They look so similiar
@Saturnus - Thank you. Also, what part of the design specifically reduces the vibrations?
Or could I just buy the two piezo Monacor MPT-001's from mcmelectronics.com instead of buying the two Goldwood and switching out their drivers for the ones on the GRS PZ1005. Any thoughts or would either route produce a pretty similar sound quality?
The PHT-407N tweeters and a cross over are preferred to the piezo from a sound quality perspective. My undertstanding is the piezo was selected because it was quite inexpensive, did a competent job, and a proper crossover was not needed, just a resistor.
Saturnus, please correct me if I am mistaken on these points.
The tweeters are ~$30 each from Loudspeakers Plus. That doesn't seem like much of a premium given all the other costs of getting a Boominator up and running.
Regarding vibrations:
The driver magnets are glued to the rib that divides the front and rear speaker 'compartments'. In essence this is one large monocoque construction with very short spans of unbraced wood. The 4" and 6" mini Boominators I built are very dead cabinets (no vibrations) even when constructed of thin materials.
It is a brilliantly engineered design.
aterren, you are correct. As I also stated just a few posts back.
In short... all of it. But I think I have adequately explained the function of each part, the considerations behind it, and why it cannot be any other way than it is previously in this thread (although some of that may be a few hundred pages back 😀)
Sorry about that Saturnus - I didn't look up the GRS or monocor drivers. I just assumed they were clones of the Old KSN piezo
@lutkeveld
I just received my email back from Sure Electronics - this is what they had to say
Dear Jonathan Paul,
Thanks for your e-mail.
Actually the AA-AB32186 on Parts Express is an old version board.
And AA-AB32971 on our webstore is an new version.
The new version has an upgrade on EMI performance and an volume control module has been integarted on it.
The old version board will has been stopped to sales. Parts will also stop to sales the old board after sold out.
Finally got my mini in working order! Still needs some finishing work but it's good to be able to use it too.
I have the 2D cutting files if anyone is interested. I widened the electronics bay to 33mm so I could fit my lifepo batteries in.
Series Coil for GW-1058
From Saturnus
"Also note that with GW-1058 I do recommend a series coil on the woofers to roll-off from 4Khz as the roll-off of the GW-1058 isn't as controlled and well dampened as the HP10W."
Can anyone recommend the right coil? The coil/inductor acts as a simple first order low pass filter, right? The impedance of the Goldwood woofer is about 16Ohm at 4Khz.
thanks
From Saturnus
thanks
My goal for the season is to switch from TA2020 into a new solution with more power to the boominator and I find the TPA3116 boards interesting since it has good efficiency/runs cool and has the ability to run on 4.5V-26V leaving up to teoretically 2x50W. The plan is to aim for 2x 35-40w and maybe with options to feed 12v, 18v or 24v for different occasions.
Now to the big question:
Would you guys consider it wise to keep a AMP9-basic for this job?? (solder it together last sunday and tested it fully functional today)
Or will it be a better choice to get rid of the AMP9 and go for the newer TPA3116 board since the AMP9 would be overkill? What about sound quality and playtime?
Saturnus - I'm going to be prepping 4 Boominator flat packs shortly for folks using the HP10W per the instructions below. Would you suggest doing the same for a signature build (SN10MB)?
The 9mm 45 degree chamfer or full 12mm round over is correct on the Boominator with HP10W (or GW1058). It serves to correct the slight dip between 600hz and 1khz.
From Saturnus
thanks
Assuming you have 2 drivers in parallel (8Ohms), a 0.3 mH inductor gives a -3dB point of 4245 Hz. Going to 0.33 mH would give 3,858kHz. Both are values available at Parts Express
Fc = R/2*Pi*L; Two 16 Ohm loads in parallel = 8 ohms.
Most recent XO from Saturnus
I finally got a chance to glue my boominator together.
There was a considerable gap (around 10mm) which I compressed with clamps, I used devcon 2 ton epoxy
I left it all clamped up for 24hrs.
Today I opened it all up and disaster struck. As I took the clamps off the bonds broke, firstly the center then one end after that a slight pull and it was all in pieces again. Any ideas where I've gone wrong? I think I used too much chemical metal which I've just spent an hour chipping off but I'd have thought the epoxy would hold better then it did.
- Class D
- The Boominator - another stab at the ultimate party machine
