Low Quiescent Current opamp
I am looking for a high quality low noise opamp but with low power consumption. I think in the near past there was some new opamps published with better power consumption?
Its for a battery powered headphone system with a total of 5 Dual opamps.
Do you need duals? And do you need unity gain stable? If you want a single and don't mind min gain 14dB then TLE2161 has Iq=0.28mA for a 6.5MHz GBWP. Not spectacularly low noise though unless you're working with high source impedances (its a JFET).
I suggest you make a little table to hold the results of your research into manufacturer datasheets. I expect a five column table would be adequate: PartNumber, Noise(nV/rtHz), Power(mA), Price, QtyInStock .
Then I suggest you put the table into Excel and make a scatterplot of Noise versus Power. Obviously the goal is zero noise and zero power, so those datapoints which fall closest to the origin (Noise=0, Power=0) are the most desirable. Circle the two or three which look most desirable according to your personal tastes, verify that the price and availability are acceptable, done.
I'd recommend that you put the Old Warhorses (TL072, AD797, LM833, NE5532) into the table as well, just so you can quickly see how much better the new opamps have gotten, compared to the Old Warhorses. Have Excel plot the new ones as big green triangles on the scatterplot, and the Old Warhorses as big red circles.
