Tom
The weenians used to have several hundred feet of cable in their test setup until someone made measurements using a resistor. They found out with that the setup had issues. So they made changes.
The improved measurement system did change the voicing of their products. The old ones worked better in large venues.
Now on one of my projects the EC sub changed the brand of wire used without mentioning it. (WPW to Gepco). As I use zobels this did have an effect. The wire specd was built for me initially and became a catalog item.
Es
Hey Ed, how's it going?
They found out the setup had issues? That's it?? Issues?
What were the issues?? Pluheeeeze, tell me more..😀
I would suspect you've had your share of cable problems. Long runs of figure 8 (zip) or twisted pairs, high proximity losses, and inductance due to tray and conduit, and capacitance to tray and conduit (I noted the zobels).
jn
Confused yoda is...... you've been 'playing' yourself all along so as to obtain a set of fairly trivial simulations from me........?I've always know that limiting bw makes them equiv, I've been saying that since before 2011.
I get it, I get it.. your mad because I got you to do the analysis for free..
I take it then you don't actually know what it physically means for a speaker driver to have an impedance |Z| below DC resistance of voice coil, but are happy to use 1R because Davis says so and it happens to drag your assumptions toward the maybe audible.......see DF96 comments on Davis treatment of impedance. See also Davis plots of |Z| for two real speakers which show no support.
As I stated up front, you needed to do it yourself. You did, thanks.Confused yoda is...... you've been 'playing' yourself all along so as to obtain a set of fairly trivial simulations from me........?
Despite your claiming that 5uSec was geologic, you now affirm the number as easy enough to do without a calculator.
Let's see...pointing out the information in the source YOU were using for cable numbers is the same thing as "don't actually know".I take it then you don't actually know what it physically means for a speaker driver to have an impedance |Z| below DC resistance of voice coil,
Yah, that'll work...
But you are very happy to ignore content within the same paper which trashes your wild assertions.
I'm sorry...did you say "comments", as it opinion??...see DF96 comments on Davis treatment of impedance.
Or did you say, actual data, as in Davis, Otala, Huttumen, and Bateman?
Wow, you are really flailing here. You want everybody to believe that two speaker measurements reflect all speakers in the universe...See also Davis plots of |Z| for two real speakers which show no support.
Read Otala and Hutumen, Davis referred to them.
Your attempts are rather laughable.
Try again..
jn
I need to do it because you can't, even though it's trivial ?As I stated up front, you needed to do it yourself. You did, thanks.
'Geological era' in the context of being easy to measure if it's there, to be strict.jneutron said:Despite your claiming that 5uSec was geologic
Yup, Davis numbers for cable params look fine to me and we need a common reference so why not?You're saying they are wrong, so point out where.......jneutron said:Let's see...pointing out the information in the source YOU were using for cable numbers
Not ignore, interpret correctly.jneutron said:But you are very happy to ignore content within the same paper
As I don't recall reading Davis' paper I am unlikely to have commented on it. However, if we are both right then we will of course say the same thing.luckythedog said:see DF96 comments on Davis treatment of impedance.
Yup. Sometimes, ya gotta stick their nose in it..I need to do it because you can't, even though it's trivial ?
Hmmm..So, first you claim it isn't there, as in geologic.'Geological era' in the context of being easy to measure if it's there, to be strict.
Then, you model it, show it's there.
Then, you say that it's so easy to calculate that you do not need a calculator...
Now, you're hedging it with "if it's there"..
Yet, you've provided calculations and model results to show it's there..
Again, you are consistently arguing with yourself..
Ah, another strawman argument. YOu first used 1 uH and a wild capacitance to prove a point, which was exactly what I was saying, then you used actual cable numbers which again proved my assertions, then you pretend that Otala and Huttunen were not referenced.
You must be getting dizzy.
You remind me of a dog chasing it's tail..
Ah, like Davis talking about distrubuted capacitance extending the high freq response?? You interpret that by ignoring it..Not ignore, interpret correctly.
He points to other authors who state 1.2 ohms min with an 8 ohm speaker, you interpret that by ignoring it.
Thanks for bumping the thread. This is actually fun.
jn
Yah, I was wondering about that as well. It appeared to be another made up thing.
By we, you mean you and Davis, or you and lucky..However, if we are both right then we will of course say the same thing.
jn
Yah, I fell right into that one, didn't I?😀Any two people who are both right!
Do not forget also the possibility that two people who are wrong can also agree..
jn
Two people who are wrong may agree.
Two people who are right must agree!
Ummmm...agreed..😀
jn
You better run... I got my crossover inductor weapon pointed right at you...No politics! 😛
*runs away*
Gonna play earschplittenloudenboomer at ya. Steppenwolf rocked.
jn
Funny you should say that. During our huddle-in-the-basement fun last night (tornadoes), I was banging around on my guitar and suddenly remembered (and played) "For Ladies Only."
No politics! 😛
*runs away*
Good idea, as long as people remember that three lefts make a right!
Best Regards,
TerryO
Just found all the cable articles on a hard drive.. I had archived it a while go, unfortunately about 4 computers back...
2 hours and 50 minutes to transfer 5 gig to an 8 gig stick..almost 3 freakin hours!!
Sigh..
I hate technology...it just passed me by so fast...😉
jn
Sigh..
jn
Best Regards,
TerryO
Didn't they just prove that on mythbusters??
With of course, the problem on Lombard Street.
jn
- Member Areas
- The Lounge
- Speaker Cable lifters or stands?
