Does anyone know the manufacturer of this outlet?
This type, similar to what Dyna used to use, is very scarce these days. Dynakitparts.com is out of them, too.
When restoring old preamps, I've just removed the socket, and bolted a small metal panel inside, blocking off the opening.
They're used in Leslie speakers. They have to be there, and there is absolutely no room to add a larger one. I found some for $10 each plus shipping. I hope that there is still an alternative source. He has to be getting them somewhere. They're not advertised as NOS, but they could be.
There is a picture in the first post.What outlet?
There is no "attachment" !
They connect to motors, and they're exposed. A barrier strip would be a bad idea.
Then there's the desire to keep the amp as original as possible.
How many do you need? I may have a few left of the type that Dyna used, like these. Not as retro, though.
AC PANEL OUTLETS NOS
I'd like to have six. Do you know how many you have?
I'll look in my parts (somewhere) and let you know.
Thanks!I'll look in my parts (somewhere) and let you know.
Thanks!
I only have two (used) ones in decent shape, sorry.
No pic for me.There is a picture in the first post.
There is no attachment.
I can see and open Rayma's link.
Thanks for checking!I only have two (used) ones in decent shape, sorry.
There is no attachment. It's a picture in the post. You might want to check to see if you have the option to display pictures disabled as part of your user settings.No pic for me.
In any case, here is a link to the external picture.
Check back with dynakitparts.com sometime in case they get these back in stock.
If not, you can make a small metal plate with holes for the mounting screws, and block off the hole with it. Just plug the amps in elsewhere.
- Design & Build
- Parts
- AC Outlet - Panel Mount - Screw or Rivet
