Choosing SMPS board for Class D
Disabled Account
Joined 2014
First of all, I'm unsure of whether I should ask this in the Power Supplies or Class D forum - I'm thinking that here is the better bet, but if not feel free to move it to the relevant location.
I'm looking to as a new project design a "full digital" Class D stereo amp, with SPDIF input using a WM8804 or WM8805 chip. The I2S signal will then go into the TAS5086 PWM processor, and the TAS5612LA power stage. A microcontroller will be used to adjust volume and switch the inputs.
All of the above I should be able to take care of.
My problem lies with the fact that for safety's sake, I do not want (or have the skill) to design my own power supply for this amp. A laptop power supply is often the common choice, but those unfortunately do not provide the 32.5V necessary for the power stage to work properly.
Therefore, I'm looking for a proven SMPS design or product that can be used for my project. When disassembling old electronic devices, I often see that their power supplies are placed on a seperate board and made by another manufacturer. I'm aiming for this kind of device, but in single rather than OEM quantities.
Thanks!
SMPS are the best choice in technical manner especially for Class-D as they can provide the lowest impedance in very wide frequency range.
But good SMPS is not easy to design or build at all. There are so many potential pitfalls in design or implementation. Enormous experience and knowledge are required and even more if you stay away from hard-switching topologies which I do not recommend at all for audio application.
By my opinion, the best choice are LLC ZVS topologies, Ćuk or phase shifted half or full bridge (PSM) converters optimized for ZVS/ZCS.
Currently, there is ongoing open hardware LLC ZVC project leaded by Macola for audio application based on Fairchild's FSFR2100 which we expect to be finished very soon at this forum:
Nas LLC sa FSFR2100
Design is conceptually oriented for less experienced builders which do not have some specific measuring instruments or oscilloscopes but without compromise on technical performance.
When design and testing are done we will publish complete project, also on this forum.
In meantime, the easiest and probably the safest way is to use classical "bulky" transformers and capacitors …
full ack!
Nas LLC sa FSFR2100
And that is why I'm looking for a SMPS designed by a professional, either completed or as a bare PCB for me to solder. As stated in the first post, I have no intention of designing my own SMPS.
