OK one last question (be honest now) have you ever been really screwed by mixing up European vs US dates, like buying a plane ticket for 5/6/1989 and showing up on May 6th.
A tip of the beenie to you sir.It's a perfectly cromulent word.
Of course. Giving date of birth over the phone in USA still throws me. Luckily I am normally forgiven for my strange colonial ways! Never got it quite that wrong though.
For example, we have gone through the $126 dollar Chinese made JC-2 line amp, and found all kinds of upgrades. Too bad it would cost $1000 in time and parts to improve it to that level.
Throw us a few crumbs JC - what mods have you done? What's the lowest hanging fruit there?
Not quite that, but I have had some problems with computer locales, because it affects how they return dates and times. It's a nightmare, actually, calendar arithmetic, reconciliation of timezones.
I did just that the past return trip back to Calif. I showed up at airport overseas to leave and it had left the day before.... [but they put me on that days flight anyway as there was space available]. My ride had no idea i would be 24 hours late into San Fransisco and had to find a hotel when he finally learned I wasnt on the flight. It can get pretty nuts going back and forth and all around.
-RM
I would change the audio wiring to get better xtalk, better power supply caps and diodes to start.
Especially if you go round and round in the same direction as to transcend time !
Numeric dates are crazy, there is no standard. Unless a form/ticket/statement specifically labels the date format (eg., YYYY/mm/dd), it should use words or abbreviations. If one says "May 6th" it is unambiguous and will never be confused with "Jun 5th". You may say "European vs US dates", but I say "no such thing"; from what I have seen, there are no real standards on either side of the pond, not even local conventions. I see this at work all the time, users supply a date in a bad format to a stored procedure and stuff breaks. One tool used at work allows adding a date stamp to a file name, and the format can be chosen from yyyymmdd, yyyyddmm, ddmmyyyy, mmddyyyy, yymmdd, ddmmyy, mmddyy, yyddmm, and you can also add the time with some additional options. (Oh, and is that the current date/time or the date/time of the report?)
Don't even get me started on time zones or the abomination called "Daylight Savings".
I always wondered why US and English people were not talking French like everybody.Numeric dates are crazy, there is no standard.
Although in Britain we would write "6th May" or "5th June", which we pronounce as "the sixth of May" or "the fifth of June".nezbleu said:If one says "May 6th" it is unambiguous and will never be confused with "Jun 5th".
Our way of doing it has the merit of keeping units in size order: day, month, year. Strangely, we all agree to say/write times in the opposite order: hour, minute, second.
I guess the other way of doing it has the merit of keeping units in the order you would write them in prose and say them: month, day, year.
When making filenames from dates the order ought to be yymmdd, so sorting can occur. I often don't do this, though, as I don't naturally think backwards!
Ah, ah, good illustration for my previous message.I guess the other way of doing it has the merit of keeping units in the order you would write them in prose and say them: month, day, year.
Add to that a management with no appreciation of the impact of fiddling with part numbers, it's a miracle I didn't go postal.
"Scientific tests indicate the effects of this technology:
Increased signal-to-noise ratio in audio signals/greater
clarity and more detailed information"
http://www.quantumproducts.com/catalog/quantum_byte.html
QuantumProducts.com
Why do I smell Jack Bybee?
se
Yes, why ?
"Quantum," "superconductor," Bay Area Area Code. But after a whois, I see that it's a Mark Berlottoni that's behind it.
se
se
Perhaps frauds all smell the same?
For those who want to know the mechanics behind it, the explanation is that the Quantum Monitor™ filter/conditioner uses a quantum force field technology, known as Coherence Technology to neutralize an inaudible noise inherent in man-made electricity. According to quantum mechanics, the closer we come to the quantum mechanical reality of life, the greater the order and energy we find. The further we move away, the more friction is encountered resulting in distortion and loss of information and energy. When the Quantum unit is plugged into your monitor and to the power outlet, the electricity flows from the power outlet into Your computer monitor and is conditioned by the Quantum Monitor™ filter/conditioner
They claim that these miracles were invented in Iowa. That should instill confidence in you.
“...I instantly noticed more clarity in voice and tone and a “feeling of clear space” as if the person I was communicating with was in the room next to me. I found the other party could duplicate phone numbers, addresses, instruction and other information without me having to repeat it! I also have found other parties to be more friendly and openly discuss other things going on in their lives. I hold off on making calls until I can get to the phone with the Coherence Technology™ because of the results. I get more done with less effort and my relationship with customers, friends and others has improved...I am positive this has helped to increase my income and assist in building this new company.” —Dennis Messer
This has got to be a joke.
- Member Areas
- The Lounge
