Circle array
Here is radial array of twelve full range drivers sandwiched between two 10" woofers:
IOW, if you just use 'FR' drivers to create a big circle, it won't work well, at least not to my ears or the others who auditioned the one I cobbled together using cheap mobile audio 'FR' speakers long ago.
GM
I meant something like this on the drawing. Creating a high sensitivity, quasi "big surface" driver.
Another version: 6 or 8 small fullrange driver and one big bass driver in the middle.
Six drivers around a seventh driver act as one big driver, so they will beam horribly. If the ring of drivers is arranged around a waveguide, you might be able to cross over before the array beams too much. But I doubt the waveguide can control it's pattern down to the crossover frequency.
True, but beaming can be a good thing to keep first reflections behind the listening position [LP] and if you focus them to mimic a point source driver you can get away with rolling the 'ring' off fairly high.
Still, the ones that worked best for me were four 15" [mid]bass woofers with a large horn in the middle XO'd @ 500 Hz.
GM
