HDtracks is proprietary aiff (apple) - booo !! 🙁
Same SQ as flac , which is compressed and open source. yeah!! 🙂
Both are lossless.
Actually have 60K+ of all three types (320k mp3/flac/aiff). Some mp3's
sound better than some flacs , source is god ... garbage in-garbage out.
Have redundant flacs - aiff -waves(.wav) .... identical.
The software (or plugin) that converts these files for your soundcard to use ,
and the D/A in your sound card (or external amp DAC) is a big
factor in end SQ.
OS
I've tried several file type from WAV to MP3. Which do you/others think are the best of the non-compression, loss-less types besides WAV files?
I've been using AIFF and FLAC mostly for all my portable stuff.
THx-RNMarsh
So, preferring some music types to others is a sign of good hearing and love of music?
Anyone arguing that way is a dead wrong from the start quasi elitist.
For the record, I am not particularly keen on Abba, but did buy them for the sake of two or three of their songs I do like (quite usual for me to buy like that) and because like it or not, they did mark an era, one I am fond of and one I wanted to round off in my small collection.
It's that simple. I also purchased a 3 CD collection of one hit wonder performers, a collection of groups who had just one hit on the charts and diappeared after that (e.g. Zager and Evans, In the Year 2525). On all 3 CDs, there's probably no more than 6 or 7 numbers I REALLY like, the rest are just collateral damage to me, and quite a few numbers which made the US chart top 20 I have never even heard of.
Am I weird because I also happen to like Three Dog Night, Cat Stevens (from the period he was still sane), Marshall Tucker band and The Incredible String Band? If so, then so be it.
It was again a sardonic tongue in cheek response to the list Sy put up, I have an eclectic collection of music, probably more so than many, as even though in my 50's I still listen to Radio 1 (in the UK) so I can keep abreast of the terrible pop music these young uns listen to today...🙂
It seems terribly, terribly hard for some people to comprehend that the process of reading audio digital data is electrical - electrical means the possibility of interference effects joining the game - change the read mechanism process, and there is a good likelihood that the non-perfect process of translating that data to a listenable audio signal just slightly varies ...
elaborate....
I've been using FLAC mostly.
THx-RNMarsh
Technically , wav/aiff are truly uncompressed (PCM). but flac is like a
zip file ... as it also becomes PCM at output.
FLAC can be compressed 50% with same SQ. I'd rather have 20K tracks
than 10K on a single HDD.
Nearly all my HQ digital is flac , converted a whole library classical collection
to flac for personal use. Convert the flac back to CD , bit perfect. 🙂
OS
That might be a part to upgrade.
let see.... didnt someone say .5-1v/v was adequate?
THx-RNMarsh
Ohh yes, most new audio products that see the light of day seem so broken that any diy-er with a hot soldering iron can unlock Nirvana from them 😉
And yes, 1V/uS most probably is enough but such numbers completely destroy any street cred with the cognoscenti, of course!
Jan
Wow! A 0.95mA Iq class B, 2V/uS opamp....? JC must must be tearing his hair out 😉
The Pono has discrete output stages. Four of them in fact as the Pono has a balanced output option. Since the chip is a quad, they may just be using it for DC servoing. Though I suppose it could be for I/V conversion. In either case, they're not what's driving the outputs.
se
dvv the restaurant down the street had MAVŽELJ on the menu tonight, do you think it was authentic? Boil pork head scraps and lungs and brains separately. Chop them. Add cooked polenta and spices. Chop onion and sauté and use them as larding. Make fist-size balls and wrap them in pork net (caul fat) separately. Place balls in baking mould and bake.
My family came from Corinthia right where Italy, Austria, and Slovenia meet. We had polenta far more often than pasta.
How can I possibly know without trying it, Scott? In general, I would expect it to be near the original because the ingredients should be fairly easy to obtain, but the rest is cook's work and taste while adjusting.
You know, when you dig a bit deeper you may find that countries which had never had any meaningful historical meets over anything just happen to have similar dishes. An example - Scotland's haggis, etc. and Serbia have a few dishes which are similar, not the same, but similar. Both are a delight to have.
This is a bit like music, or specifically, musical instruments. Drums, flutes and bagpipes seem to be common to every single nation in Europe, despite variations on the basic theme.
This never fails to cheer me up, because it shows that we are all similar, despite the politicians' attempts to make us all appear very different, local customs notwithstanding.
se
Thanks, I had servoing as a thought after posting that dismantle link. It was just too bad if Pono used that OP as output.
Actually, I still listen to classic FM broadcasts day in, day out, 8 AM to 12 PM. And there are moments when I get caught out on visually checking whether that's my FM tuner or my CD player I'm listening to.
That's possible because locally I have 3 radio stations (out of 62 stations overall) which do give a damn about the outgoing signal, 2 of which are dead set against MP3 and the like, they broadcast only proper CD material off real CDs. And they do have their glory moments.
Unlike the modern junk kids are served as pop, and especially RAP. Locally, we have an additional category we popularly call "turbo folk", designating music which uses classic folk music lines, but adjusted to modern instruments by just about every idiot on the block. Most of it is plain and simple junk, designed to cover up the singer's lack of vocal talent and to highlight her boobs and behind. Unfortunately, boobs and behind can't sing.
Talking of "doctoring", the point is made, yet again, in the last few minutes of the video https://www.youtube.com/watch?v=2NdpLAeZvEs - I wouldn't have been able to present it better myself ... wasn't that impressed with his glass CD, should have sounded a lot better - but the presenter got the general idea ...
Thanks Frank for that YouTube link....i watched bits and then the last 5 mins or so....I have to watch my data usage 🙁 .
Anyway, yeah, been there done that with modifying laser pickups, I can get better sound than that $2000 glass cd disc (you cannot be serious !) for close to zero cost.
That said, it is most interesting that the actual cd material can make a sonic difference...I have gold metallised discs and they have another sound again.
So, yes, the point is made that 16/44 can be good, bloody good, and better than many give credit to.
Dan.
elaborate....
We've been here before, marce, a few times ... 🙂
You sort of explained it in your next post,
Nah it will be pretty much the same, all the DACs I have seen the insides of are nothing to write home about.... Mundane layouts etc.
Something as simple as a layout, and/or quality of power supplies is enough to do it - in the latter area a number of members have done recent work, and managed major gains in subjective quality.
Cross-interference shouldn't be a factor but the reality is that it is ... enough to be audible ....
There is no way to cheaply emulate an expensive circuit.
No way to to package 1 pint of beer into a 1/2 pint glass.
In that sense, John Curl is right, in my view - there really is no substitute for a well done discrete ciruit, beause with it, the designer keeps full control of each and every parameter of the sound it produces.
That would be especially true if cost is the main selling point of the circuit.
Just remove half of the water. You can always put it back again later. This is what people who like 'tube buffers' claim to do with (digital) music.
I read somewhere (possibly in this very thread) that chip designers have access to matched devices (or predictably mismatched devices) which allow circuit techniques that are simply impossible with discretes. Of course, they also have to face things like thermal feedback which discrete designers can avoid.
I suspect that nostalgia is the main driver for discrete circuitry. Just like some people prefer valves, or even low mu valves driving interstage transformers. It may also be a preference for 'hand-built' over 'factory-built' - although few commercial circuits are really hand-built, as it is too prone to error and sample variation.
