Hawksford
Nelson Pass said:
Is this familiar?
PMA said:
Looks like voltage error sensing circuit.
Might been a signal splitter if the signal input was in between emitters of the transistors on the left side.
Nelson Pass said:
I'll give you a hint. It's a bias circuit for a complementary
follower output stage.
PMA said:
Thanks. I'll think about it.
Well - you probably meant the circuit that I have attached. The results are incredibly excellent. I am not gonna show the values not to tell all. Congratulations, Nelson.
OK, I'm game.
If I look at that circuit, I think that the two transistors in the middle-right are acting as a Hawksford correction: The output signal is at their emitters (through the diode offsets) and the input signal is at their bases (through the left-hand transistors BE and diode offsets).
So, assuming the output falls too low, Ic of the top/middle/right transistor increases. That would pull down the upper gate only to aggravate the too low output. BUT, it also lowers the base voltage at the input stage upper transistor (IF it's the input stage, nothing seems conventional here), and that lowers the input stage Ic, therefore allowing the upper gate to rise through the current source. So, the ratio of the resistor string appears to by crucial for the exact times-1 correction.
The diodes in the output stage appear to be there to avoid cut-off (or, more correctly, reverse biasing). They are then also needed in the input stage for correct DC bias throughout the amp.
Jan Didden
andy_c said:
Apologies in advance for the verbose post that follows here 🙂. I finally took some time to read through the article www.elecdesign.com/Articles/ArticleID/7207/7207.html, and I disagree with some of the points made. His points include the following:
1) The gain-bandwidth product of a conventional voltage feedback op-amp or power amp in rad/sec is gm/C.
2) When the differential input voltage to the input diff amp is not negligible, the instantaneous differential input voltage swing, combined with the diff amp nonlinearity causes gm to be modulated.
3) This modulation of gm causes the gain-bandwidth product to be modulated.
4) Modulation of the gain-bandwidth product causes instantaneous phase modulation, that is, AM-to-PM conversion in RF speak.
5) The performance can be improved for a fixed gain-bandwidth product by decreasing the open-loop gain and increasing the open-loop bandwidth. This is best done by loading the VAS with resistors to ground.
By "modulaton", I mean "varies with the instantaneous value of the difference-mode input signal". I'm describing his points here, not necessarily mine. I agree with 1-4 and strongly disagree with 5.
Let's set aside for the moment whether these effects are audible and just look at the mechanism. Let me try to demonstrate why I disagree with 5. To do this, let's assume we have two hypothetical amplifiers that we can change, subject to the following restrictions:
A) The input diff amp can't be changed
B) The compensation cap can't be changed
C) All we can do is change the open-loop gain and bandwidth while keeping the gain-bandwith product constant.
At a fixed output frequency and amplitude, it's clear that the amount of phase modulation is determined in a direct way by the amount of modulation of gm. Since the phase is being modulated at the same rate (frequency) as the signal itself, the modulation sidebands just show up as normal harmonic distortion. But let's forget about harmonic distortion for the moment and just compare how much gm is being modulated in the two hypothetical amplifiers. Further, let's assume a sinusoidal output voltage whose amplitude is independent of frequency.
Let's take an amplifier with a 20 MHz gain-bandwidth product. Assume its open-loop bandwidth is 2 kHz and its DC open-loop gain is 10000 (80 dB). Suppose we decide to modify this amp so that its open-loop bandwidth is wider, say 20 kHz and its gain-bandwidth product is the same. The DC open-loop gain must be 1000 now, or 60 dB. Further, assume the modifications meet the requirements of A, B and C above, maybe by putting collector resistors to ground at the VAS output as the author suggests.
Let's assume a large 50 kHz signal at the output of both amplifiers, and assume the slew rate is high enough so there's no gross distortion. Since the gain-bandwidth products are the same, the Bode plots for both amplifiers fall right on top of each other at frequencies above 20 kHz. So the two amplifiers will have almost exactly the same open-loop gain at 50 kHz. If we take the output signal amplitude and divide it by the open-loop gain, we get a difference-mode input signal that's the same for both amplifiers. Since the input stages are the same for both amplifiers, and the differential input voltage swings are the same, the instantaneous modulation of gm is the same for the two and therefore the AM-to-PM conversion is also the same.
Now take the same amplitude output signal at 1 kHz. We now have 20 dB more open-loop gain in the amplifier with the narrower open-loop bandwidth than the one with the wider open-loop bandwidth. Dividing the output signal amplitude by the open-loop gain, we get a difference-mode input signal that's 20 dB lower in the amp with the lower open-loop bandwidth. So at lower frequencies, there's actually much less modulation of gm in the amplifier with the lower open-loop bandwidth due to the decreased differential input voltage swing.
So the feedback is not the villain here! At frequencies above about 20 kHz, the performance with regard to the phase modulation is the same for both amplifiers. But at frequencies below 20 kHz, the phase modulation is less in the amplifier with the lower open-loop bandwidth and higher open-loop gain (because we're assuming a fixed level output signal, and the open-loop gain is larger, and therefore the difference-mode input is smaller). While it's true that this phase modulation will no longer be independent of frequency from low frequencies to 20 kHz, it is always better in the amp with the lower open-loop bandwidth than the one with the higher open-loop bandwidth (remember we're assuming the gain-bandwidth products are the same between the two). Not only is the feedback not the villain, but it's improving matters at the lower frequencies.
So the idea of putting collector resistors to ground at the VAS output only degrades the theoretical performance with respect to phase modulation below 20 kHz, and keeps it about the same above 20 kHz. The original Leach amplifier in the Audio magazine article in February 1976 http://users.ece.gatech.edu/~mleach/papers/lowtim/feb76feb77articles.pdf had these resistors (R20 and R21 in Figure 2). However, later versions http://users.ece.gatech.edu/~mleach/lowtim/graphics/ckt.pdf omit them. This issue was the subject of debate back in the late '70s and Dr. Leach changed the design. He specifically mentioned at that time that what was really important is not the open-loop bandwidth, but the gain-bandwidth product. Removal of the resistors brought about improved conventional distortion performance without sacrificing transient capability.
While the phase modulation concept has a valid theoretical basis, for two otherwise identical amplifiers with the same gain-bandwidth product, the one with the larger low-frequency open-loop gain and smaller open-loop bandwidth actually has an advantage with respect to theoretical performance in this area. It's a mistake to blame feedback for this.
Hi Andy...
Thanks for this most illuminating forensic analysis....
Cheers. :hug:
"...So the idea of putting collector resistors to ground at the VAS output only degrades the theoretical performance with respect to phase modulation below 20 kHz, and keeps it about the same above 20 kHz. The original Leach amplifier in the Audio magazine article in February 1976 http://users.ece.gatech.edu/~mleach...b77articles.pdf had these resistors (R20 and R21 in Figure 2). However, later versions http://users.ece.gatech.edu/~mleach...raphics/ckt.pdf omit them. This issue was the subject of debate back in the late '70s and Dr. Leach changed the design. He specifically mentioned at that time that what was really important is not the open-loop bandwidth, but the gain-bandwidth product. Removal of the resistors brought about improved conventional distortion performance without sacrificing transient capability..."
Maybe it is not necessarily bad to have the collector resistors to ground at the VAS output? Is it possible that a properly selected value for these resistors could "stabilize" the open loop VAS gain so it is not affected by the load under high power conditions?
Fab
Loading the Vas with resistance to ground is a perfectly good
technique, used in the Aleph 0, 0s, and 1.0. Yes, it increased
the distortion figure slightly by anchoring down the load
impedance that the VAS saw, and thus limiting the open loop
gain figure, but I liked what I heard, which was more spectral
consistency and less variation with load impedance.
It's not always appropriate, but I always at least try it to see.
Nelson Pass said:
...... but I liked what I heard, which was more spectral
Somehow i don't think you can 'hear more spectral consistency'....or 'less variation with load impedance'.....
In any case, these dubious quantities cannot rationally be 'improved' by making the design more susceptible to supply line hash....which is what happens when one arbitrarily reduces LF foward path gain by resistively loading down the transimpedance stage (TIS!!!)....
Moreover, the later increases TIS distortion, while simultaneously depriving the major feedback loop of the gain required to reduce it.....an altogether horrendous faux pas....
Theory versus Practice
As usual, theory is not always born out in practice. 😀
Re: Theory versus Practice
It's expected that theory won't in general be born out by non-scientific practice. And I don't think Nelson's making the claim that his final decision was based on a scientific approach. He just went with what sounded better to him. Nothing wrong with that. If you consider the scientific portion of what he said though, namely:
Originally posted by Nelson Pass
Yes, it increased the distortion figure slightly (...)
then the theory was born out in practice. Loading down the VAS increased the distortion consistent with the theory.
How do you know what Nelson can or can not do?
I know one thing that he can do:
Make amplifiers that have met the acceptance of many consumers, over a considerable period of time.
Not an easy feat.
And his critics have done..............?.......what........?...is that silence that I detect?
Oh, yeah.....I know.....write articles on how he doesn't know squat about SOA.
Jocko
The folly of youth...
mikeks said:
Rather patronising i dare say.....If by 'practice' you mean the 'evidence' of your ears in unscientific listening 'tests', then give me well reasoned, and proven theory....any day.....
Actually, I'd be willing to bet that you're the one doing the "patronising". Why? Because I doubt you've taken the time to do the listening tests yourself.
I know where you are coming from because I've been there myself. Luckily, I was disabused of that particular arrogance at a very early age, while still a teenager.
All it took was an afternoon. We rounded up all the best preamps of the day, me the "scientific" skeptic and my friend the "hands-on" audiophile. All of them had what was considered then to be "perfect" specs -- frequency response +/- 0.25 dB (this for the phono input of course, as that's all there was back then for high quality sources) and distortion less than 0.1%.
To my complete shock and surprise, the audible differences were laughably obvious.
Try it sometime. You might learn something. It's like they say, "the mind is like a parachute -- it works better when it's open."
