3 direct coupled 2A3 amps
The swing you require depends entirely on where you run the GM70.
To increase swing with a pentode driver increase the plate load resistance and supply voltage. You will usually have to adjust the plate voltage upwards as well to move the operating point further away from the plate curve kinks. It's pretty easy to do once you obtain a graph of the curves. All you need is a ruler.
Pentode - Triode
Does that tube have enough swing for a GM70?
General question, why build an amp with a pentode front end tube, when a REAL triode tube is available ?
Also, Thorsten's implementation of the pentode is soo soo common, and so sub-optimal, a drop-down resistor from the main B+, and a cap to ground !!! Ugh.
A pentode really should have a TOTALLY SEPARATE grid supply, if you want to do a pentode "right" as possible !!
Easier and better to use a triode, without that extra grid in the way, say I !!
Jeff Medwin
Hows this look for some voltage swing?
Don't pay attention to the remaining circuit (its a cut and paste), but seems to do about 18 watts.
deafbykhorns, a properly implemented pentode driver can sound excellent. I have used a variant of the posted C3g driver schematic with gas tube regulated screen and can vouch for its ability.
The g-k voltage on the schematic you posted is a whopping 128V, so you would be aiming at being able to generate at LEAST 150V clean swing each way. You would therefore be looking at a Vp of around 250V for a C3m driver, which would limit you to around 16-17mA current (I am looking at the Vg2=150V curves here btw).
The advantage with using a pentode in this application is that you only need the one tube and can also dispense with the costly interstage iron.
Other candidates that come to mind are the D3a, C3g, EL84 or perhaps the Russian 6P15-EV. A 12AX7 simply won't work in this application.
Jeff,
With a low DCR power supply the last thing you would appear to want in series is a tube rectifier. Yes, they are 'traditional' and all that, but in terms of technology they are the worse performing element from the tube era.
The 5U5G sucks 3A for a 5V heater - that's 15W burned right there - the biggest use of power anywhere in the amplifier. The plates will drop 44V off the B+ rail, which is hardly desirable, more wasted power.
The dynamic resistance of this rectifier is spec'd at 21R which pretty much negates any benefit you wanted from low impedance chokes.
If the issue is the B+ coming up too quickly - there are other solutions that stay out of the way once the rail is up and ready.
I assume your listening tests prove that the tube rectifier works best - but can we say why ?
Not my words that follow, in discussion on 12-24-15 of Solid State vs FILAMENTARY rectifiers on efficient speakers ( the kind of speaker you use with tube amps !! )
RE: tube rectifiers: cannot detect differences with my Quads...only on the Khorns-nT - Cleantimestream - Tube DIY Asylum
I use the new JJ 5U4GB, very nice filamentary rectifier tube !!
2A3 DC Article - 1994
Don't know of I've seen all the Loftin White variants, but if there's any other, I am pleased to have it pointed out.
Goldenbeer:
Ever see this one !! Lovely article, take a look.
IspraNet Audio: Direct Coupled Single Ended Amplifier
My 2015 vote is half a vintage smooth plate Telefunken, etc. 12AX7, DCed into a modern JJ 2A3-40 and use of a JJ 5U4GB rectifier tube. L1/C1/L2/C2 filter to 2A3 Finals, with all Ls under 10 ohms DCR.
More common are people who don't know how a Loftin-White works.
Really?
In fact they haven't built any Loftin-White. They have only made a simplistic DC coupled amp.
I would ditch the cap from B+ to screen and keep the one from screen to ground. Two caps form a voltage divider for any ripple on the B+ to the screen. Not a good implimentation.
Your right, it didn't seem to do anything for the circuit after running the sim.
However, my bandwidth is really bad after the pentode, almost a 5 db drop at 20hz.
I like my SIM of the 6BL7 better, it seems to drive the GM 70 into A2 slightly when needed.
I'm not sure that he modelled an interstage with a pentode driver, which effectively makes its use redundant. That would be a recipe for total disaster, especially if it was designed for use with a low impedance triode like the 6BL7.
Yes, I simmed 124
The plot is after the pentode before the cap, that's were I read the drop in freq. response(which of course carried thru the IT and OPT).
IT is 5k, is that bad to use this with a 6bl7? I thought it would be better if the grid starts pulling some current on peaks. Plots look pretty good or am I missing something?
If you are using a pentode driver with sufficient swing there is no need for another tube or an interstage tranformer. Just cap couple it directly to the GM70.
If you really want to use triodes + interstage transfomer, then 5k sounds about right for a 6BL7.
