How hard is that to get across the boarder?
Easy , spend 20$ , pour it into a large spring water bottle ... declare it as a
"spring water sample" (or flavored SW) - ship it.
Sent some to NY , never over the border. 😕
OS
Input 'black gate' i use , good .
Blackgate might be good for a coupling- feedback - bootstrap app. But as
a DC blocker , stick with a panasonic/Nichicon 35V BP.
Black gates can be in a semi-shorted state until burn-in (carbon "hairs").
OS
I Can recommend:
Blackgate N for DC blocking
Elna silmic 2 for decoupling analog
Oscon SP for decoupling digital
Please OS ,can you post two different schematics for two options?
Are you paying me for design ? 😀
Default schema and artwork match. Voltage options are unavoidable.
OS
Happy new year!Are you paying me for design ? 😀
OS
No i can't do it😀
Ok i will come back with measurements😱
Happy new year!
No i can't do it😀
You did the thermal coupling perfect !!
Can't wait for the test !! 😱
OS
Yeah , getting the "bugs out" and SOTA - only on this channel. 😀
Edit - Thimios is gifted ... what a cool way to thermally link multiple pairs. A
longer one (C shaped) could do all 4 pair !
OS
OS
Ok, here you are.You did the thermal coupling perfect !!
OS
It is unstable yet...
The measurements
All recommendations welcome🙂
Is the rail 47V? Thanks.
The measurements
Looks good for the 47V rails.
"Hammer" it with square waves . 😀
OS
Ok, here you are.
What was the final outcome? Did you get it stabilized or is this still a problem?
I didn't try anything up to now.....What was the final outcome? Did you get it stabilized or is this still a problem?
I will wait OS advice😀
Remove "cbp 1/2" .I didn't try anything up to now.....
OS
Come on Thimos, where is your better than usual building and testin speed.. Still jet lagged from new years grub???
Did it have thermal drift..??
No, thermal drift is gone.
But this IPS is unstable (cbp1/2 removed).It is periodically unstable.It is the first IPS making zobel resistor glow like a lamp!😀
- Slewmaster - CFA vs. VFA "Rumble"
