I don't wish to sound negative, but you really cannot do a "High End" design on a single sided PCB, only a budget design.
At audio frequncies, a well designed single layer board will always outperform any poorly designed multi layer board.
Its digital, digital needs a full ground plane for return currents, for best signal integrity...
You are more likely to have problems with a single layer design, to many compromises have to be made. A double sided should be bare minimum for anything other than the very simplest circuit.
I am curious as to what you would define as a poorly designed multi-layer.
I created pcb with only one output and replaced 4134 with 2134 DIP version, for those who like to swap their opamps like me😉
Great work, zdr!
I think I will use your on my next board 🙂
This are my results.
Digital signals have a lot of high frequency spectral content. As such, they require strict adherance to proper ground loop current flow design rules. This is much easier with a dedicated ground tightly coupled to the source signal, but this is not impossible to accomplish with single layer design.
I cannot think of a situation where I would choose single layer over multi layer, but I do not agree that a single layer cannot do a high end design.
My definition of a poor design is a design which doesn't perform as well as it could. I am certain I could create a single layer design today which would outperform my first multi layer design.
Opamp is reversed, don't use the files. I will correct this soon an post new onesI created pcb with only one output and replaced 4134 with 2134 DIP version, for those who like to swap their opamps like me😉
A single sided digital design is never going to be high end, to many compromises, no power plane capacitance, no proper decoupling and NO GROUND PLANE for return currents, a two layer is pushing it, a single layer never.
We could develop a dual layer with power plane for this project.
It is not that complicated to transfer using toner.
Could someone print a PDF version of the schematic, I don't use KiCad so cant read the files please.
Hi all,
I've been interested in this project for a couple weeks, but I had a few reservations.
The main reasons are that it is a single-sided board; it was so large; the quad opamp was a bit odd; and I don't use KiCAD. As clumsy and outdated as it is, I and many others prefer Eagle.
I've transcribed the original schematic into Eagle and designed a two-layer board with a ground plane. I also changed the quad op amp in SOIC-14 to a dual in DIP-8. I envision using either OPA2132, OPA2107, AD8620, or LME49720, but any fet-input dual op amp should work.
JanErik, I hope this is OK. Let me know if this bothers you.
I've attached the .sch and .brd files as well as a couple PDFs of the schematic and board layout for those who may be interested. I use Eagle version 6.4 so it should work with anything 6.4 or newer, including 7.1 and 7.2.
Thanks 🙂
EDIT: I forgot to mention I changed the resistors to 1/8W (saved a lot of space), changed the output to 1 pair RCA (two separate connectors for increased durability), and two aux output pads to use whatever connectors you'd want, or to wire it directly to your amp or headphone amp.
Thanks 🙂
Hi all,
Thanks 🙂
Thanks but zip file is corrupt. Can you check it and attach again.
My apologies, I don't know what happened. I tested it myself, it should work this time. If for some reason it doesn't, PM me your email address and I'll send you the files unzipped, if you're interested.
The ICs would benefit from small SMD decoupling capacitors next to the power pin.
There is a via very near a pad as shown below, this is a possible short during assembly, it would be better moved away. The route from R23 would be neater if it went directly to R21 then to the IC.
I tried converting my pcb to dual sided, but components are already dense enough not to see any major benefits in that, so leaving it as is. People will have a choice between many flavors. This is the latest version with USB A connector, to plug the entire module directly into laptop.
Sounds good, zdr. I'm about to revise mine & double check for errors and then send them off to the PCB fab. I'll chime in when they come back & I've tested it.
I'm just curious - when you choose to use "high-end" in the name - what specifically did you have in mind at the time?
- Digital Line Level
- JEDAC - yet another take on a DIY high-end USB Audio DAC
