That limiter uses Led/Transistor optocouplers, which distort a lot.
Use Led/LDR .
Agree. I would use VACTROL, such as VTL5Cxx, or NSL32...
Sajti
No LDR used its behringer limiter 2N7000 transistor along with BA4558 ic
This is not limiter, but turn on delay only...
Sajti
PHONIC input limiter😉
Hi, I did some test with JFET limiter, about 20 years ago. It was well working,
but it needs another opamp comparing to the LDR version...
Sajti
post#8 download schematic nice limiter
It's not possible to download unfortunately...
Sajti
What are you talking about? 😕
No 2N7000 nor BA4558 visible in your posted schematic. 😎
file:///C:/Users/Andrew/Downloads/behringer_cx3400_revc.pdf
This file is in your C harddrive and only you can see it.
That is another thing. See the attached picture.
Sajti
Sajti
Nice to see on post #15 what you were talking about in post #8 🙄
I guess I'll have to get one of these:
or at least get a ride in this:
It was just a little help to Andrew...🙄
Sajti
Dear Sir,
This file cannot be downloaded.
Can you please share it through PM?
Thanks and regrds,
Sumesh
- Limiter section
