That solder paste stencil looks like a neat alternative to a solder syringe when doing multiple boards. I'll have to try that.Have you guys seen this before?
DIY solder stencils from soda cans | Hackaday
Reflow Toaster Oven with Bells and Whistles RAYSHOBBY.NET
You have redraw these for smd devieces?
Not yet. Just redraw, because i don't like bmp 😀.
Do you mean beatmap?Not yet. Just redraw, because i don't like bmp 😀.
Lets start with cfa-x #post 701 .🙂Yes, bitmap. Which one do you want to make as smd ?
I must leave now i'm one step before fire test "calor gold".A class A amplifier by Dr Borivoje Jagodic
First you have to have a list of equivalents for the SMD and TTH devices. I saw one once on the forum, but I can not remember where it was posted, "I think"...
Yes, all TO92 transistors ,but better is to wait OS answer.Just change some resistor and cap to 1206. Anything else to change ?
Have you KSA1381E & KSC3503E?KSA1381 and KSC3503 is what I put in mine.
MJE340/350's do not really affect OPS performance when used as predrivers.
THD is slightly higher and the CFA IPS's slew a bit slower when these are used
as VAS devices.
I have both the 340/350's and the 1381/3503's on hand. Gain wise, both (340/350's)are
100+ current gain. 1381's are higher (e =200+) , and most of the 3503D's are <140.
We aren't getting a match anyhow - NO 3503 - e's 🙁(mouser does not stock them).
Dang , for a symmetric VAS ... like the CFA's - spooky , I might use the 340/350.
At least they match (gain wise).
Symasui and wolverine are designed to compensate for the 1381e/3503d "mismatch" .
(wolverine and symasui are both "upside down" 😀 - positive CCS/level shifter).
OS
as VAS devices.
OS
The regular suppliers seem to have ksa1381E and ksc3503D. Is it OK to mix the ranks in the wolverine circuit?
OS types faster then me...
What I meant with the wolverine/symasui -
Since they are "un-symmetric " to begin with , the mismatch really does not
matter. If you wanted to be anal , you could adjust the gain of the active side
(the 3503's Re) to compensate for the gender differences.
The CFA's "like" a better match. (In simulation) , my "Kypton-C" CFA's servo
has to provide more feedback with a mismatched VAS pair.
Lazy cats SMD CFA uses very closely matched devices - he don't need no servo.
Through hole has it's limitations... (especially with a {non-servo'ed}CFA).🙁
OS
A good start , but by SMD ... I mean ALL SMD.
- ALL the semi's can be SMD , even the higher Ic VAS one's.
-all diodes -SMD. -all resistors -smd , even the big Zener shunt ones.
- Large caps , trimmers, euro-terminals would be the only through hole devices.
....shrink it down to 76mm X 35-40mm (3 X 1-1/2") 😀
OS
Hi OS it is useful if you can post a complete list for all IPS where needed matched trans.in VAS.MJE340/350's do not really affect OPS performance when used as predrivers.
as VAS devices.
OS
OS
Just think about it !! "Needed" might be a overstatement. "Preferred" would be
appropriate.
The servo is quite the little helper 😀 . For example , the "spook" - VFA , just a
few tenth's of a milliamp DC feedback will correct a unbalanced VAS.
CFA-X will need a few turns on one of the trimmers to do the same.
They all still work in these conditions , but they work better without.
OS
- Slewmaster - CFA vs. VFA "Rumble"
