New to me Mitsubishi Stack
I picked up a Mitsubishi DA-A30, DA-P30, and DA-F30 tonight for $100. The DC offset needed adjusted and a fuse that controls the indicator lights needs replaced. Once I get the fuse replaced, I'll hook it up and see how it sounds. It's pretty clean and from a non-smoking home. Once it gets lit up, I believe it will be a pretty impressive set-up. I've never owned any Mitsubishi stereo gear, so I'm anxious to see how it sounds. The amp looks pretty beefy. I believe it is a dual mono configuration.
Can anyone explain the difference between the AC and DC inputs on the power amp?
Thanks,
Mike
