Tony's 6C33 pp amp build progress....
i am building myself a push pull amp...
OPT is 800 ohm anode to anode, to 2, 2, and 8 ohm speakers
the output tubes topology.....
driver tube will use the 6LU8, the pentode side will be used as cathode followers....
the triode side will be a long tail phase splitter...
i plan on using the 6J9 as input tube.....
more later...
Great! /I think 400 ohm for every tube is small load, if You use one tube for a channel/. Or connect 8 ohm speaker to 4 ohm output.
/....very long PP amp, 6SN7 will work good as phase splitter, if You use one tube for channel, 6J9 is good addition to 6SN7.../
Sorry, I have a mistake ........"if You use one tube for a shoulder"...../not channel... in both places/. The tube has Ri about 130-150 and more depends of current, this data is for current about 400-500 ma...if You use in PP small current, Ri will be bigger and 400 ohm per tube /shoulder in PP/, IMO, will be small. /I used OT 1.2 kohm per tube/.Distortions will increase. Tube sounds itself some aggressive and sense of sounding will be, IMO, some discomfort.
chassis preparation....
aluminum, 3 mm thick and measures 20in deep x 14 in.s wide x 3 in height..
power traffo and choke....
power traffo is made out of a 1 3/4 inch center leg, stacked to 3 inches and can handle 750 watts...
filter choke is 1 inch center leg stacked to 1 3/4....
