Kypton -V
Just before testing.
Pete, Please do not "Muntz it"before you get it going good. Thanks.
That's precisely what I would advice. Thx!
Besides, compared with the PMP or PGP amp, it has already been "Muntzed". 🙂
Cheers, E.
See: Madman Muntz - Wikipedia, the free encyclopedia
"He often carried a pair of wire clippers, and when he thought that one of his employees was "over-engineering" a circuit, he would begin snipping components out until the picture or sound stopped working. At that point, he would tell the engineer "Well, I guess you have to put that last part back in" and walk away."
If I remember Mad Man Muntz correctly, he was from Southern California and made his fortune putting the first radios in cars. I wasn't aware of the being Muntz'd story though!
Just before testing.![]()
Still4given added the "Csp1/ 2" . Super-pair has no native Ccb (capacitance).
Kyptons were the first with Baxandalls , Stillforgiven made the first (second 😀)
oscillator 😱 .
OPS might oscillate without these !!!
15-22pF will do for these.
(below) shows this. Kypton-C already has these as main compensation.
OS
Cheers, E.
Give me a break , Ed ! I only "muntz" enough to get it (the designs) to the
soldering table. The TIS can not be muntzed to <18 semi's to serve its
true purpose (sub PPM perf.) - the way it is...
PS - Thimios ... you have become EXTREMELY refined in the toner transfer prototype
department !! WOW
OS
Hi Thimios, I just observed from your builds... is that a metallic wrappers around the transistor pair? and what is the the purpose? Thanks.
Comin' right along ... EFA
"excellent flippin' amp" is progressing nicely 😎 .
Hawksford and the "H" bridge stages are nearly "mirror image". Comp.
Caps are short traces to ND- PD+. (below 1)
The 2 diamond inputs are the only ones that need "face to face" coupling.
I have a feeling this amp will "fly". Really linear at 170v p-p - low THD -
with the CFA's slew rate .
It will "eat" square waves of this magnitude , as well ! 😱
OS
OS
Finally decided what Thimios will "wrap with copper" (below)
For a "fast" IPS , all traces must be "short and sweet" .... they
cant meander or run parallel (with other traces) for a long distance.
I added some parasitic trace capacitances to the rails of the IPS (in LT) ,
my initial .1uf decoupling negates them nicely.
This layout should be capable of (at least) 300V/us with the slewmaster
OPS.
I also thermally modeled the whole circuit - slightly negative co-efficient.
this is preferable (to a positive one).
All this is where "the rubber hits the road" -
When I have a real amp , all this will be physically resolved before the
"road". I just want to design to make Thimios's life care free. 🙂
PS - I thought I would share some of the "moonshine madness" that
goes into these designs (in real time - live) "I think i'm alive" (or is this a dream 😀).
OS
OPS.
OS
very coolPS - I thought I would share some of the "moonshine madness" that
OS
very cool
Even as I am "crazy" ... this is good !
To think "outside the box" takes life experiences that most do not have.
My "take on this" is very practical ... the "nuttiest " members supply the
concepts - I convert it to the "real thing" (another IPS.)
OS
OK, I'll stay out of it.Finally decided what Thimios will "wrap with copper" (below)
OS, and others please give me a comment of my simulation here: http://www.diyaudio.com/forums/solid-state/264732-new-output-stage.html
Very good !! Next "victim" 😀 .
DDC and DDV IPS's...
OS
I think I just further delay the EyeSee 🙁
Sansui diamond differential or John Curl H bridge with two AD844 output :
http://www.delapucealoreille.com/
http://www.homecinema-fr.com/forum/post178243980.html#p178243980
http://www.homecinema-fr.com/forum/post178248183.html#p178248183
OS
Very true
De la puce à l'oreille - Acoustique et lectroacoustique
Le Bistrot des DIYers - Page 91 sur le forum Travail de Groupe - DIY du site Homecinema-fr.com - 29967818 - 1
I'm actually working on the design, rather similar to the top picture with AD844, but with my own discrete operational amplifier with OTA topology 🙂
Lots of current mirrors 🙄 Another "crazy" thing 😛 But looks promising...
I will try without these....first.
Please OS ,is this in circle capacitor 500pf?
yes , or 470pF would do.
OS
- Slewmaster - CFA vs. VFA "Rumble"
