Tall, upward firing sub. Help requested.
Can someone help me design a subwoofer / helper woofer similar to the design on the second to last page of this document.
https://www.passdiy.com/pdf/el-pipe-o.pdf
I want to make it from wood (not a Sonotube) and it would be square (not round).
Goal: The goal is to make a tall, upward firing enclosure that won't vibrate the floor in my apartment. I don't want to disturb the neighbor below. I want to use the ceiling as bass reinforcement and I plan to place this in a corner. I am hoping by making the opening at the top (I'd go as tall as seven and a half feet - my ceilings are 8 feet). I am hoping this type of design, especially with the woofers open at the back, would not vibrate the floor much.
Can someone model a simple enclosure made from plywood that would generate bass down to about 50Hz or lower using a typical 8" woofer? I am not looking for state of the art performance, only a solution so not to bother my neighbor. Additionally, what specs would the woofer need to be?
Currently, I'm using an H-frame with Eminence Alpha 15's. The floor vibrates so much!
Many thanks in advance!
Zilla
Zilla
Hi Zilla,
Have a look at the submitted Pictures:
b🙂
I have tall subs almost 4' mltl, that use a 6.5". Even with force cancellation the acoustical energy is plenty enough for any neighbor to hear. Without force cancellation they vibrate only in the vertical plane. Altho Im on a slab, attention to this detail is important and should be minimized. These vibrations are not so deep as to cause this annoyance, what comes out the port certainly does.
