Volumio (ex RaspyFi) Audiophile Music Player for embedded systems
DSD still not working as well in either DSD direct or DoP.
After enabling DID dac, it somehow breaks hifiberry dac setup. Makes it sound like music is in fast forward, which it somehow is since the songs end quickly.
All the same thanks for the effort.
DSD is not working with USB DAC or I2S?
Hifiberry sounding too fast is related to a problem I discovered today on some system, an update is coming soon. It would help a lot if you share your configuration
Using RPI with LAN port, but not latest RPI+, hifiberry i2s dac on-board. Using recommended wifi dongle. Powered USB by 1.5 amp tp-link hub. RPI is powered by 1 amp power supply.
With Direct DSD there is no sound. With USB cable using DSD over pcm sound is distorted with static noise.
DSD dac is Schitt Audio Loki.
Input receiver: c - media cm6631a
D/a converter: AKM4396
DSD capable: DSD64
Analog topology: AD8616 with DSD specific filtering
100ma power consumption.
SD-card still not working in Read only mode, no support for Wolfson Audio Card...but useless Spotify Premium Support.
There are no real Improvemnets in this Update.
Perhaps it would be better to stop the battle against Rune Audio and do some real work.
Give more hints about how Volumio is being build and there is much more Community Support...
Despite I am not a Volumio user or author, I still found the comments are offensive and rude! 😡
Mike needs be Congratulated and we should be thankful for his on going efforts! What if there no other platform? So for the owner of such childless comments,
Ask not what Volumio can do for you!, ask what can you do to improve Volumio?
Best,
Chanh
Best,
Chanh
+1
I don't really understand getting so bent out of shape and telling someone to stop developing a project they are working on and giving away!!
Kyle
A little help please for a network challenged ancient...🙂
I have a Pi running latest Volumio and it is utterly wonderful !
It has a wired connection to my router and I can control it from another pc loging in with 'volumio.local/' Everything works.
On my Android phone I am using Sound@home app and can connect wirelessly,via the router, to the wired Pi.
Again everything works, but the Ui for Sound@home is not suited for my device making it difficult to navigate.
I would like to try the web interface using the Android device, however, it cannot connect using volumio.local/ and when I try inputting the Pi ip address it just times out.🙁
I have tried different browsers to no avail.
What is the step I am missing...🙂
Have you tried Firefox, Chrome or Proton?
I saw PI and breezed over IP.
Also be sure if you have used these browsers or the browser which is packaged with Android, that you clear the web cache in the browser settings.
Internet Explorer and Safari don't work well with Volumio. I tried in the past.
If you have both wireless and LAN connected at the same time on the PI, try only LAN first. Disable one from PC.
Another thing you can try is download a terminal app.
Ping PI ip address to see if PI replies.
At prompt type ping [ip address] then enter. No brackets.
I've found a new thread in a volumio.org about i2s on Udoo: [Solved] UDOO I2S Output : Help - Volumio
Sadly, but I bought Udoo as I undrestood from a Volumio web site, that it is possible to use i2s with Udoo using Volumio.
I think, that it is unfair from Volumio in an Udoo feature list to write that Udoo has 3.5mm jack, HDMI, i2s, Coax S/PDIF outputs, but not mention that not all from these features are supported from Volumio.
So, I paid about 150eur for an Udoo, and now I have to sell my Udoo lets say for a half of price I paid or just throw it away and have to buy some another device hoping that it will support i2s. Nice!
This is the problem with "ready for everyone, no need to know anything" DIY linux appliance projects. For me as a long term linux user that list is obvious - I would always check availability of the driver first.
Well, yes, it is a misleading information. But the whole principle is wrong. There is no "no-brainer" DIY linux appliance and if developers present one to be so, it is not honest. Errors/problems always arise and require skills to fix.
In addition to that - the "Only older kernels are officially supported (3.0.35)" is a no-go for anyone having used linux for longer time. Drivers (e.g. support for various non-standard USB soundcards) are added to new kernels and often impossible to backport to ancient versions such as 3.0. Clearly this device will be very hard to update, unless the manufacturer (community?) releases a working new kernel (likely or unlikely, toss a coin).
I know I did not help you with your udoo. But at least you can take it as an opportunity to learn 🙂
Things are much better now.
Played 16-bit, 24-bit 44, 88, 96, 174 and 192. DSD still distorted.
However, the quality of the other 16 and 24-bit formats has improved noticeably.
For example, on tracks with depth, I can more clearly pin-point instruments.
On the Audiogon Wake-up Your Ears compilation, the track "Stank" has a drum kit that is deep, dead center. Now I can hear the snare, hit-hat and kick drum separated in space, and it's deeeep! Very nice. I liken it to the quality of version 1.41 when a track is placed completely in RAM.
Using the Buscia kernel profile setting.
Title: Stank (4:45)
Album: Explorations in Space and Time
Artist: Jamey Haddad/Mark Sherman/Lenny White
Genre: Jazz
Composed by: Lenny White, Jamey Haddad, and
Mark Sherman
Published by: Chesky Productions
This is very good work.
Thanks,
Vince
FAB, go to volumio.org and join the forum. There is a DAC forum there and it has a sticky post listing available DACs. You might not have to join. Might be able to view the forum without joining. You'll get more answers there.
Vince, I have already checked and found recommended Dac but they are mostly es9023 and pcm5102 Dac in I2S which I already have. These 2 are not my cup of tea since I find the sound too thin compared to my other setup ( udoo and usb xmos+Ak4399). I am hoping that with ES9018 with I/v stage with selectable opamp I can get the sound I like in a second setup upsing the pie...
Fab
