A little bit happiness to share🙂 a given box: lots of toriods 2x12V 30VA...sad 🙂 but good for another project.
100x 2SK170 BL.....tomorrow...or on sunday...some pleasure matching.
You could add 2Vac of turns to each secondary.
you end up with a 14+14Vac transformer.
That is enough to run a DCB1.
I will do a measurement first. The transfo's are rated @220VAC prim. So...adding 230-240 to them will rise the 12VAC sec also. Gonna take a look.
should I take 2 in parallel (two transfo's)...for increasing the 30VA....which is maybe to low for a stage one warm-rodding🙂
For sure I have to measure this with a load on it.
30VA & 28Vac (14+14) gives an AC current rating of 1070mAac.
That is equivalent to a continuous maximum current rating of ~535mAdc when feeding a capacitor input filter (the DCB1).
If you draw 60mAdc, then you are using ~11.2% of the rating on the +ve side. The -ve side draws a bit more depending on how you set up your relay drivers.
If you hot rod to 200mAdc then you are using ~37.4% of the rating. This should still run cold if the transformer was any good to start with. It is worth checking your transformer's idle current over the full range of mains voltage, 216Vac to 254Vac.
Is 200mAdc worth trying?
I always recommend that for continuous duty, the transformer be limited to <50% of it's DC capacitor input rating.
Maybe a stupid question. Is it for a particular reason to use a 9V battery for Idss measurement? Is a bench power supply also ok (with a voltage regulator LM317)?
Of course. Preferably with current regulation.Is a bench power supply also ok (with a voltage regulator LM317)?
STAX,
Glad you found the mix-up. Everyone of us has done the same thing at one time.
It takes longer to measure each R before the build, but, doing so allows you to pair L&R channels a little closer by swapping the minor value differences. Can I hear the difference? Probably not, old cloth ears. But I don't mix up values any more either. 🙂
Ron
Ron
2SK170 matching is done...wat a work, but enjoyed it 🙂
best pair is 7,27 - 7,27 - 7,29 - 7,29 mA
lot of other usable pairs, but this one is even close between left and right channel.
Toshiba and Linear both specify 10Vds for Idss measurement.Maybe a stupid question. Is it for a particular reason to use a 9V battery for Idss measurement? Is a bench power supply also ok (with a voltage regulator LM317)?
9V is pretty close and is generally good enough for rough batching.
Scorpion board troubleshooting. ..
Well, well I found the culprit. ...on LEDS in one of the triplets (non-working side) was "open" ...When my stubbornness pushed me to get an even better measurements matching, I probably overheated one and ended up with a bad connection (no signal continuaty) between the LED and the following component.
Found it while doing a continuity test. Just had to put a tiny copper jumper underneath the board and the thing finally worked.
Final measurements
LEDS: 9,86V and 9,93V
DC Offset: 1,0mV and 1,3mV
Vdrop: 1,28v and 1,36V (down from 1,47V)
Good to go?
Thanks a lot to you all
Scorpion
Final measurements
Good to go?
Scorpion
Salas,
I bought the temperature probe, here are the results with a Mills 1,25R @ 12watts ccs..
Results were measured OUTSIDE the enclosure
Ccs resistors: around 65°C
Rectifier diodes: 56 +/- 2 °C while sinked
Mosfets: 34 +/- 2°C
Heatsinks: 48 +/- 4°C
Temperatures varie slightly on almost every readings (thus the +/-), so stated values are averages.
Scorpion
Mosfets: 34 +/- 2°C
Scorpion
Is that a Type K thermocouple DMM wire sensor?
Nope. Digital Temp probe with laser pointer.
Like this?
Or like thi$?😀
Or like thi$?😀
Like this?
Or like thi$?😀
Wow !!!!😱😱😱
More like the one above but blue in color and not by Fluke. Paid around 50$ for it. Probably average stuff, but it gave me an idea...
Scorpion
DCB 1
Dear sals
My measure is
DC offset 0.3 mv and 0.0 mv
V drop 1.891v and 1.881 v
LEDs 10.05 v and 10.06 v
It ready to go ?
Dear sals
My measure is
It ready to go ?
By hopefully that 0.0mV does not mean discontinuity you are ready. Zero can't produce any harm anyway. Did you hear the output relay click?
- Analog Line Level
- Salas hotrodded blue DCB1 build
