OK, so let's look at power conditioning first then... since I got that line R unit, what would be a recommended upgrade?
Those little IEC filters are rubbish.
This ^ .... +1
Used them on a DIY preamp, and they created a lot of junk/noise. Troubleshooting the noise source led me to these IEC filters as the cause. Who would have thunk? 😱
Removed it and replaced with a plain IEC AC inlet, and noise magically disappeared.
Do yourself a favor and do a little test.
Get a cheap home heater, the type with 2 "stick" quartz tubes with wire resistors inside.
They typically are 1800 to 2400W, read the label and post it here.
Plug your meter leads in a wall outlet and record voltage.
Then turn both "sticks" on in the heater (plugged in a nearby outlet, preferrably in the same wall and of course on the same phase) , measure the new wall voltage .
Obviously you use 2 different outlets, one for measuring, another for the heater.
Post heater power consumption as rated in its label and both wall voltages (before/after).
If you want to repeat measurements 4 or 5 times and post them in a table, better, we'll be able to average them and have more precision.
Please post them here.
Try to use a good multimeter, a poor low precision one probably won't furnish useful measurements.
Lets go one better.
What is the REAL problem you are trying to address? By real, I mean one you have identified and traced to source, not some imagined "narrowing of soundstage" or "loss of air when I play Toscanini"
Lets go one better.
Yes, that's excellent advice!
One of the most frustrating activities is searching for invisible black
cats in dark closets!
Best Regards,
TerryO
Those little IEC filters are rubbish. .........
How many agree?This ^ .... +1
How many disagree?
So far 2 agree they are rubbish
and 1 disagrees.
This post tells me everything I need to know about why not to buy audiophile power cords. Mind you, I like better mechanical quality of the more expensive connectors.
Mechanical quality is the only actual reason, anyone who spends more than 20 or 30 dollars on a mains cable expecting anything other than mechanical reliability would be better off listening to Crossing Over with John Edward instead of music.
and 1 disagrees.
They are rubbish if you select a wrong or inappropriate one. They work very well if you select the correct one. Key is current draw.
Current as in keeping the load (much) smaller than the filter's rating or matching the rating to the load?
A 6 amp filter used in a 500mA circuit will not do much good, so closer to the latter. The manufacturers' datasheets are very useful in this regard. They usually give attenuation vs frequency curves as well, so you can choose depending on what noise it is you're trying to suppress.
I'd much rather think that you had some hairy grounding problem, and you corrected it, knowingly or not, when wiring the IEC connector. 🙂This ^ .... +1
Used them on a DIY preamp, and they created a lot of junk/noise. 😱 Troubleshooting the noise source led me to these IEC filters as the cause. Who would have thunk? 😱
Removed it and replaced with a plain IEC AC inlet, and noise magicallydisappeared.
I have 3 off 6A IEC filters. Unused because I don't have equipment that needs that high a rating. 6A is equivalent to 1400VA.A 6 amp filter used in a 500mA circuit will not do much good, so closer to the latter. The manufacturers' datasheets are very useful in this regard. They usually give attenuation vs frequency curves as well, so you can choose depending on what noise it is you're trying to suppress.
I am getting through my stock of 1A and 3A IEC filters. I would even use the 3A on a 800VA transformer fed amplifier.
One selects the current rating to suit the load.
That's what I suspected, but always nice to have verification. Thanks!
This ^ .... +1
Me.
It wasn't magic. It was a logical outcome based on the actual problem.Removed it and replaced with a plain IEC AC inlet, and noise magically disappeared.
Accurate statement..I'd much rather think that you had some hairy grounding problem, and you corrected it, knowingly or not, when wiring the IEC connector. 🙂
jn
Apart from cost, any reasons to not go oversized ? - eg, 6A filter powering preamp.I have 3 off 6A IEC filters. Unused because I don't have equipment that needs that high a rating. 6A is equivalent to 1400VA.
Dan.
Amperage matching is "ok" if you want parts to fail. Try to go 2x as high.
These are awesome. You can try to evaluate them on their inductance, but if you check attenuation you'll notice they all are good. Coilcraft Combination Line Filter Choke
You won't lose any dynamics unless you chose one too close to the device amp rating.
They work better with X capacitors. Several is advisable, and even on seperate sides of it ("Felix") filter. You can use multiple values. the less you have, the more the quality of the cap can vary attenuation (sound). It's best to have the poles opposite from eachother, a zig-zag of wiring, for cancellation.
Y caps that go from hot to ground cause problems depending on the grounding scheme in equipment. It could be less noise than without, in a noisy environment. However audio isn't that noisy. I know it sounds funny, but despite the overall amount of noise that isn't within most people's houses or gear, the difference conditioning makes can be everything.
Y caps from neutral to ground can be flavor assortments too, but you're better off with a few smaller and then something large like 100-300mfd.
Nope. It wasn't a grounding issue. I didn't change any wiring.
The IEC AC filter I used was emitting RF noise. The preamp channel physically closest to the IEC AC filter was noisier than the farther channel, that's how I discovered it. Replaced it with plain AC inlet, and no more noise.
It could be a defective filter unit, as it was bought from an online surplus store.
It can still be a grounding issue. In fact, it's a very good possibility that the filter you used pushed line hash directly onto the ground of your preamp, and your layout is susceptible to that. By removing the filter, you broke the coupling path between the hot and ground.
jn
- Power Supplies
- power cord upgrades, and power conditioner
