Tube-I-zator Professional PCB
It's Alive!
The V3.1 Tubeizator is running...!
I used the Rhopoint resistors for both Rk and Ri/v. The sound is very good in the early stages. I will post more comments after 100 hours.
On the V2 Tubeizator, I used the "naked" resistors for both Rk and Ri/v. While the Vishay's are very good, for this application I much prefer the Rhopoint.
Thanks for a very good upgrade board Oliver.
Oliver
I am finally getting around to putting the Tubeizator into a case 🙂 I did a search but couldn't find the answer to my question which is;
The transformer I have has a 2A 9v secondary that runs the heater supply, does the heater supply need the whole 2A? I was wondering if I could run the Twisted Pear Placid HD PSU from the 9V secondary as well?
Oliver
Witch tubes are you using?
I was toying with getting a new version of the Tube-I-zator but they are sold out🙁
Do you think it would be possible to easily implement the soft start onto my V2.0 board? Every time the tubes flash at start up I cringe.
I've finished my DAC with tube-i-zator v3.1 and Ian's FIFO kit. However, the heatsink of IRF840 is quite hot (around 50-60 degree). I can't touch it over 1 sec. Is there anything wrong?
Input is AC150V and B+ output is DC150V. All components are brought from Mouser in accordance to BOM v3.1
Thanks!
Thanks!
Sorry I cannot answer your question but do you have a build thread for the DAC looks interesting.
How sad......Seems like I arrived a few years too late.
At the price they were I can't believe the sales dropped off.
A lot of the SRPP output stages seem to be discontinued now. Hopefully something comes up on the 2nd hand market. Has to be a few unpopulated PCB's lying around somewhere.
Really want the Tube-i-zator though and not willing to settle for anything less.
