With the A series modules I would need an appropriate voltage(s) SMPS, correct? What voltages are required for the 250A series?
Rick
Rick
Rick
Well, usually we use 500ASP or 250ASP to driver 250A directly, haven't used individual smps to driver it, so really can't help you about this issue. maybe others have experienced it?
Thanks ghentxu. I see now from the ICEPower website how the 250ASP is used together with a 250A amp module for 2 or 3-way setups. Purchasing just the 250A modules limits my immediate options. I'll research on their website what DC voltages they recommend to adequately power just a 250A module. - RickWell, usually we use 500ASP or 250ASP to driver 250A directly, haven't used individual smps to driver it, so really can't help you about this issue. maybe others have experienced it?
I recently acquired cary caa 1 power which uses ice power module. Got the unit with non-working one channel (mono per module) and the power transformer also shorted. Emailed cary but didn't get a reply.
Found this thread in my search but seems the modules layout not the same with this model. Other manufacturers also used same module type like; Jeff Roland, bel canto, ps audio and d-sonic magnum.
Ghentxu or anyone can point me where to source replacement would be much appreciated.
Another question, any chance to fix the module? Thanks.
The Cary amps I know of use the 200ASC module. There are some for sale here on diyaudio - search the buy/sell forum.
/U.
/U.
/U.
Many thanks for the info...
Will do the search... 😉
It seem there is also 200asc for sale, if you need: B O Icepower 200ASC 200W Mono Amplifier Modules w Power Supplies | eBay
ghentaudio
Ghent Audio --- Do something for HiFi Fans
ghentaudio
ghentaudio
Thanks for the link... 😉
I noticed some differences on the module I have and the one post. More caps and larger size. Is it possible due to different versions and I. Have older model?
Yes, the ones on the e bay link are the latest Rev L versions.
Thanks for the confirmation.
What is the differences on the various revisions?
Are there any sonic difference on the revisions?
There are still a number of the 200ASC boards left here:
http://www.diyaudio.com/forums/swap-meet/261358-b-o-icepower-200asc-class-d-200w-w-universal-power-supply.html
New DIY Chassis for NC400/NC1200/UcD700
Hi Everyone,
Here you are: Pair GK Ncore MX DIY Mono Case Kits for Hypex NC400 NC1200 UCD700 Ghentaudio | eBay
This GK-Ncore-MX Mono(XLR input) case-kit, is specific designed for multiple combination of Hypex modules:
Greeting,
Ghent
Hi Everyone,
- NC400 + SMPS600
- NC1200 + SMPS1200
- UcD700 + SMPS1200
Greeting,
Ghent
New DIY case-kit for ICEpower 250ASP/500ASP/1000ASP
GK-ASP-MX (only XLR input)
GK-ASP-MXR (Both XLR & RCA inputs)
Chassis size:
Chassis size:
- Internal size: 193mm(W) x 70mm(H) x 315mm(D)
- Face-plate: 8mm thickness; (Silver face-plates are also available)
- Rear-plate 3mm thickness;
- Vendor's Bazaar
- FS: ICEPower 125ASX2 module
