For an "all horn system" a high efficiency woofer solution is often selected in order to deliver both matching details and matching dynamics. "Fast Bass" comes from a wide bandwidth woofer with modest Mms, modest Le, plus a strong motor in a big box. For bass, efficiency = big.
"Fast" bass has been done to death. Lets not introduce red herrings...
Chris
Wow and it still works ! Is the surround/cone original ?
Works like a charm! Everything original, even the phenolic suspension. In a horn, if you want the ultimate performance, field coil is the best. IMHO, of course, but many of my audio-friends agree.
Right.
Since humankind discovered solid-state diodes and big capacitors (and all kinds of low-ripple big-ampere power supplies designs), I've been wondering when field coils will come back.
Do we have to wait until the Chinese turn off the neodymium tap to get up the motivation? (Kidding)
Now that we don't have to worry about speaker magnets polluting our CRT colours, can anybody explain why we don't see modern field coil drivers with mega-force?
BTW, can a DIYer make, rebuild, or augment their own driver with a field coil? Not too much we do with drivers these days... for good reason. And not much we can do with magnets except for planar drivers.
Ben
We do see those, but with an astronomical price tag attached - virtually thousands of $$. Fortunately, there are still many used FC drivers that float on ebay at a reasonable cost.But we digress...on the subject of bass...I noticed (maybe I'm simply growing older and something is happening to my hearing) that too little bass id much preferable to too much bass. There just needs to be a hint at the fundamentals and the mind will fill in the rest. Until recently, I had a 35Hz sub, but it had to go on account of very low ex WAF. No, nothing will come close to horn sub, but... That's why I'm going through the trouble of building two sealed box subs.
I can see why massive field coils and associated power supplies have to be expensive when in a retail driver. But so are trick magnets and the equipment to make them.
On the other hand, folks who roam surplus electronics stores might be able to make one cheaply. How about that?
Footnote on bass:
Some judgments the ear makes poorly. But ironically, using test gear you can educate your ears as to what truly low bass sounds/feels like. Likewise for high treble.
As Toole's research shows, ears have trouble distinguishing a treble boost from an upper bass droop, etc.*
Ben
*present company excepted
Footnote on bass:
Ben
Have you measured this driver's TSP's, do you know Bl and Re?
No, I haven't and I'm afraid to do this. Because the system performs fabulously and I'm happy. What if I measure and find out that performance is not very linear and there are all sorts of anomalies? How am I supposed to sleep after that? Been there, done that. Generally speaking, I'm very sensitive to brightness and my speakers tend to be somewhat rolled off because I tend to bring tweeters down by a db or two.
At least you are honest about it...
Well, you see, measurements and linearity is a strange beast - especially when it comes to horns. A system may measure very linear but your years will tell you that something is not right. And then you start listening and tweaking and end up with a system that doesn't measure all that well. I say, trust your years. Because it's you who you ultimately trying to please.
I think the quality of the driver is important no matter what frequency it is reproducing. Of course, there is no direct, invariable relationship between quality and price. But I never heard the lower frequencies reproduced the way I imagined they could be until I invested in a pair of used TAD TL-1601b and put them in 170L ported cabinets. Probably not suitable if you want explosions and 16 Hz cannon shots, but fabulous for music.
Imo it comes down to space and cash, if you have space but little cash lots of 10-12 inch subs give the best displacement per dollar and can be built small, large nicer drivers can get away with less boxes and more power handling but cost 6x as much at times. I almost always go the 4 driver route because some auto drivers are verrryy respectable mechanically and are dirt cheap. Ymmv, if a customer is willing to pay for the best driver, I give them what they want
They manage it with MRI machines. (Kidding of course)Surely for really high-powered field coils, (I^2)R losses become huge. Dissipating heat in the voice coil would be a real challenge.
Chris
But the general configuration doesn't have to closely match permanent magnet models. The pole metals can be chosen according to heat flow considerations.
Frankly, I have little intuition about what a field coil would look like. Or even if it had to have an unvarying force.
Ben
Ben
Field coil is just that - a coil of copper wire. Hook up a power supply to it and vous a la - you've got a magnet.
The field coil strength is still limited by the saturation of the ferro magnetic return structure wether it be a low carbon steel or some other more exotic material. Nowadays neodymium is the fashionable choice for a number of practical reasons, but there are still some applications IMO where a field coil might be the better choice. The NRT or Neo-Radial long gap configuration could probably achieve a higher field strength in the gap if someone put some time into it.
Dan - thank you for recognizing I wasn't asking a simple-minded question, whether about coils or MRI machines.
I suppose the magnet design issues are similar whether talking about a lump of copper coil or a lump of neodymium. But there must be opportunities for fresh thinking using coils, as you suggest.
But now I would like to ask a simple question because I don't know much about magnets: in a new thread.
Ben
Any specific suggestions for a 2 sq ft sealed box?
18" Jensen FC driver in my 35Hz horn sub was the finest driver in that application I ever heard. Unfortunately, this driver is sinfully expensive even when one is lucky enough to see one on ebay.
- Subwoofers
- Expensive drivers - are they worth the money?
