F5 power amplifier
That means the two channels are working identically.
Or, is there a difference you have not revealed?
Channel A
I turn one pot one turn then turn other pot one turn
observe Iq and offset proceed one then second pot , for DC output 0.0 Volt
and R11 R12 0.45 Volt.
Channel B
When I move P2 (one turn), DC output rises quickly (approximately 150.0 mV)
and few mV in R11
I move other pot (many turn) increase mV in R11
and DC output 0.0 volt.
I move P2: No increase mV in R11 and DC output rises quickly to 150.00 mV
I move P1 many turn: (no effect)
I move P2 many turn: (no effect)
A shot in the dark....I'm not knowledgeable enough to translate between circuits, but those adjustment problems sound very similar to what was happening with a bias boards on my BA3. In that case a defective Q204 was the cause. Maybe one of you gurus can determine if the same thing might be happening here. :)
Channel A
Channel B
and few mV in R11
I unsoldered all passive components and have them checked.
I soldered the components. I replaced Q1 and Q2.
Best result after
P2 many rotations
P1 2 rotations
measurements
dc output 78 mV
R6 + R8 (68 ohm) 0.20 V
R5 + R7 (68 ohm) 1.04 V
R12 0.48 V R11 0.49 V
R4 4.58 V R3 4.86 V
R14 (47 ohm) 52 mV R13 (47 ohm) 29 mV
It hurts my head
I have to succumb my ignorance!!
Your almost there, you have it biased up to 1A.
Slowly adjust P1 & P2 for 0.56V across R11 with close to +/-20mV offset at the output, if you can achieve 0mV offset, all the better.
Alternatively, you could leave it as it is and adjust P2 for best offset, it just means you wont achieve the full 25 Watt of class A into 8 ohms.
my amp does not work so I can not do better.
I'm looking for the fault.
