choose the best loading for professional woofer
those figures aren't real bad for half space - its 15.5" deep by 17.75" wide by 48" tall. Ask some of the guys real good with hornresp in the subwoofer forum to model some tapped horns and tapped TQWT-s for that B&C - if you already own then might put it to use - it looks like a high fidelity unit as a direct radiator.
here's an old thread at Speakerplans where I got the idea for the pipe and the aperture - look at the simulations - they should help you get an idea on how to use hornresp for this case.
Plan ! - D-20 (hz) Macro Sub ..tapped horn by moi. - Speakerplans.com Forums - Page 1
thank you freddi :)
is very compact
high fidelity unit :confused: naaaaaaaa :D
I am doubtful because until now these woofers have been disgusting...
I really hope that this woofer will suond better with these boxes :rolleyes:
however, I want to do a test and throw 45 euro to build a test box...
I keep you informed :spin:
thanks to all
I do this test:
2.36 meters lenght Tline
if the box works I paint it and I will build the second.
otherwise transform the box in a tapped horn or other.
:crazy: :D :eek: :hbeat:
very destructive.... with 200watt the dishes in the sink begin to dance
drumming with the hands it seems too resonant :confused: ...
but when it starts to play you fall in love...
clean and deep bass...
incredible...
new photo!!!
This is the place where we will do aperitif this summer :D
Saturday I spent a day to pass a cable 3x10mm^2 (26m lenght) for powering the amplifiers
the cable is directly connected to the differential relay
from the relay to the main cable of 20mm^2 there is a cable of 6mm^2 (0.5m lenght)
the cable passes in a corrugated under tiles
I intercepted it in a well and I made a cassette with an industrial socket
Now the subwoofer has a sound much more clean and precise :D
Now the 12" mid-woofer are not keeping up with the subwoofer
