Tympani 1D Rewired with Foil Help with XO
I recently bought a pair of Tympani 1D,S that were in a bad shape so I decided to re-wire the bass/ mid panels with alum adhesive foil 5mm width 30 microns. It turned out great but I didnt particular like the 1D tweeter so I rebuilt an old MGIIIA ribbon tweeter to run with the bass panels which sound good. My xo on the tweeter has a 1mh coil in parallel and Iv got 32uf in series the question is do you think that is suffice to crossover at + - 1khz?
Hallo Afrika schau in meinen Block Facebook "Magnepan Lautsprecher Reparieren" ich kann dir die Tympani-ID Tweeter Reparieren, der Original Tympani-ID Push pull Tweeter fängt bei ca. 1.100 Hz an, der MG-IIIa etwa bei 3.400-4000 Hz er kan im Betrieb mit 1.100 Hz kaput gehen Grüße der Mägi DOC Christoph
