1.8ft3 sealed
Yes, in fact the Dayton Audio RSS315HF-4 needs slighter bigger enclosure than the Eminence LAB 12 (the Eminence Lab 12C High has also less LF extension) on a sealed 2ft³ = 56.6L.
http://www.oaudio.com/docs/manual_v1_6.pdf
http://www.eminence.com/pdf/LAB_12.pdf
(specsw) amp: 325W RMS (into 8Ω load @ <0.01% THD)
Setting the filter to 25Hz (2)
F3 = 48 Hz - (with filter on) 320.9 W (2): pic of freq and excursion shown below with filter activated.
F3 = 43 Hz - (no filter) (1)
(1) amp@listening levels/power, (2) amp using@max power
I wish I could find an Oaudio bash amp, I believe they went out of business a few years ago. I already have a 500w bash amp from PE. Oaudio had a parametric EQ and adj subsonic filter, the PE version is fixed. as far as the graph I cant read whats at the top.
ah I see thats pretty close to what I got with winisd and another program that uses excel. I was going to buy a 300w a/b amp and turn it up all the way but I already has a 500w bash amp from a prev project I will probably use. if I set the amp gain to 12 oclock (250w at 4ohms) how would that correspond to driver at 6ohms?
You don't need filter if not abusing it, I would say.
F3 get's lower.
You can have the amp measured for max. speaker output () but I don't think is necessary.
The Lab12 has a max excursion between 13mm to 22mm (Xmech) before destruction. 😀 😀 😀
What is best/recomended volume for LAB 12C in closed box,for music and HT use ?
I'm thinking about buying one (maybe a pair)
, so I can use one driver per cabinet and make two subs (one for each chanel) or maybe use two drivers in one cabinet ?
I belive that one driver in closed box would do for music and HT use ?
Any advice should I use two drivers in one box ? (Does it make sense?)
or just to buy one driver and place it closed box ?
( the smaler the better 😉...I have read that people have use LAB 12 in something like 30-40L closed...but I can get 12C which is lettle diferent )
I'been thinking...
I think that I need something relativeli small...
maybe to build something like coffe table with driver downfire...
othervise I would have box which have high of 35cm min...
so maybe I should stick with one driver in compresion with downfireing ? (made as coffetable)
Whell,I could build something like 50L -60L if its gona be like coffe table.
I have try to simulate LAB 12C in winISD and have F3 of around 50hz in 40-60L.
So I'm wondering should I go with peerless XLS 10 (30L) with scan speak pasive radiator instead 12C ?
Tnx 😉
But I would stick to those two 😉
Peerless XLS + SS PR at around 200euro and LAB 12C which I can get for 200euro (per peace).
If I would now start to think about some other solution I think that I will never build one 😉
I can live with one box 30x30x30 (or 35x35x35) for XLS+PR 😉
Have to think 😉
Thanks for advices 😉
