I was suggesting that unless the chips were handled correctly with regard to ESD between manufacture and customer.Could it be that there are no "Fakes", just chips that have been handled without regard to their very high sensitivity to ESD?
From what I have read, static does not always kill the chip immediately, it can shorten it's life and/or effect it's performance.
Thanks for the replies.
This particular stereo board has the rectifier, soft start and speaker protection built in. I just added a 22-0-22v transformer and a heatsink.
I get the feeling now it was an isolation problem that caused the chip to blow, leg 7 must have got very hot, the board was burnt. The other channel is still working
The smell of burning remained in the house for hours, reminded me of grilled Kippers.
I hamfistedly removed the burnt chip and managed to knock off a couple of pads on the topside of the board.
Is there a simple fix for this, I was thinking of a spot of conductive paste?
Thanks.
Well, I should have said, you can rosin flux the broken copper track, and then solder a regular wire to it, to mend it.You can flux a broken paste and solder a regular wire to the copper track.
Thanks for the reply Daniel.
There only 1 damaged copper track, which is on top of the board and it's very fine, probably too fine for me work on!
I followed the track and it leads to a resistor, so my idea is solder a wire between the resistor, where it comes out of the bottom of the board and the pin? I think I can do that!
The amplifier is up and running again and sounding great. Not show and tell, luckily the 3 bridging wires are underneath the board!Yes, go for it. Just check with the ohmmeter afterwards to see that the connections are as you intend them to be.
- Chip Amps
- 7294 chip went bang???
