Mullard 3-3 PCB
Here is my latest, and I think final version of the PCB. The main change is moving the NFB components closer to the relevant pins on the EF86. Time to bite the bullet and order some.
Cheers
Ian
  • Screenshot from 2014-06-27 17:55:16.png
Are caps C6 and C8 mounted by the tube or under the board?
If they are by the tube I think they will toast running SE.
M. Gregg
They are beside the tube but neither is very tall, perhaps 25mm each. The valve footprint on the PCB is for a socket so the valve itself will about 10mm above the PCB and the first really hot bit a good 10mm above that so the two caps should not really get very hot. Having said that, there is probably room to move them a little further away.
Cheers
Ian
Will you make your own PCB's or get them made.why did you opt for a PCB rather than point to point?
Re last post-by this do you mean using a transformer to reduce the line level of the input or in between/in place of the FB resistor/cap?
I've read that the EF86 can be sensitive to high input signals. As others have said the are plenty of alternative pentodes to use in the front end,but not sure Ian is overly concerned about this.That said the EF37A can be a good replacement pentode for the EF86.
Andy.
I designed the PCBs and had them made by Iteadstudio.com. 10 PCBs for less than £20.
I am no good at mechanics. I hate making holes in a chassis, especially big ones. I have arthritis in my hands and I find using a Q-max punch quite painful. So I prefer PCBs. The plan is to build a stereo amp in a 3U rack mounting enclosure
Not to reduce the line level but to convert it from balanced to unbalanaced. It will be followed by a level pot.
Andy.
It is possible that the sensitivity of the 3-3 as designed may be too high for my needs. If that proves to be the case I will experiment with increasing the NFB to further reduce the distortion. The advantage of the EF86 being directly coupled to the EL84 is that is reduces the number of poles in the loop by one which should allow more NFB without stability problems.
Cheers
Ian
Cheers
Ian
Reply to a very olde post. But the pole on the pentode connected EF86/Z729 screen may not be where you expect it.
