Help with minor ground loop when both RCA connectors are grounded
Hi have a minor ground loop that I'm trying to 100% eliminate in my amp build that only happens when both RCA connectors are connected. With a single connector, the ground loop is gone (speaker dead silent). Can someone provide a suggestion on what to change in my grounding setup? I have a diagram of the connections attached.
Moderator
Joined 2011
Try 10 Ohms between each RCA ground shell and ground. Float the RCA jacks from the chassis, if they aren't already. Should work.
