Fun with 604E
Hello, I would like to build boxes for my Duplex.
I have come across various designs on the net. I might build it similar to the 620 cabinet or larger.
Space will not be an issue with these cabinets.
I have read that these speakers can be used in around 20 cu foot cabinets, although 5-9 cu foot is more typical.
Right now they are in 5 cu foot boxes which obviously do not sound flat.
The point of me buying 15" 100 db speakers is to get good sound without any EQ, even if this means having the equivalent of two refrigerators in my listening room.
So I guess my first question is how big can I go to improve bass without compromising the glorious sound of these bad boys?
Second question, actually more opinion, does anyone have a prefereence in sound between the typical vented box vs MLTL with this driver?
I tried my hand at WinISD, but the driver does not appear in the database, I was unsuccessful at entering the data manually. I assume the documented T/S for the 604E would get me in the ballpark without having to measure my set, although I do not object to that.
Also I did join the Altec Users, but the website is messed up and I am only half registered lol. There appears to be a lot of technical problems there. Too bad, it's a good little site otherwise.
GM
Joined 2003
Greets!
Well, if you research me [GM, GPM, among others] you’ll find my preference has been Harry Olson’s late ‘40s tall reflex [vented tower, column, MLTL] alignment since I was exposed to it in the ‘60s ;).
The largest cabs I recommend for < ~ 0.4 Qts drivers are typically Vb = Vas, Fb = Fs, so for the 604E, the largest MLTL can be up to ~27.5 ft^3, though the largest actually built to my specs IIRC was 17.64 ft^3 net/tuned individually to each driver’s Fs [< 30 Hz] by a professional horn blower in NYC and set up in a relatively tiny room/near-field listening app [home recording studio monitors? Can’t remember now].
Driven with a matching impedance SET, he was a ‘happy camper’, with solid bass down to Fs, but this was well over a decade ago now, so no clue if they stood the test of time.
Specs have varied quite a bit over the decades of re-coning, so considering how far out of spec some of GPA’s re-cones have been, I’d be leery of designing around the old published specs unless yours are still OEM and not been seriously abused with high enough power to heat weaken the motors; otherwise, ‘smart money’ is to measure their specs.
I sent a PM to the forum’s moderator about your sign-up problem, so hopefully it will be resolved soon.
WinISD or WinISD Pro alpha? Best to use the latter, for which I have many additional drivers plus there’s a tutorial and driver database here:
WinISD Pro Tutorial and Download (A detailed guide on how to use WinISD Pro) - Home Theater Forum and Systems - HomeTheaterShack.com
Downloadable WinISD Pro Files - Home Theater Forum and Systems - HomeTheaterShack.com
GM
Hello I'm the Moderator over at the Altec Users Board and will see if I can help you with your problem.. So Sorry for your problems registering.. Steven is a great guy and will send him a PM ! I will try to get you fixed up in a hurry and BTW Welcome to the Board ! I assume you are trying to register under the moniker SNR ?
Regards ~ AB
Great to see you want to get the most out of this wonderful coax! Box alignment and crossover are the obvious keys to your project.
First is to get an accurate measure of the woofers T/S values. Have you measured them?
I also assume you are aware of Jeff Markwarts interesting site about phase correct crossover solutions. Jeff Markwart's Corner - Phase Corrected Crossovers
I have not measured them yet. I will see if I can put together a testing rig this weekend. Any objections to using Rod Elliott's technique for this?
I did come across Jeff Markwart's crossovers, however I failed to mention that I acquired a pair of N-1500 A crossovers. If I understand Jeff correctly, I could just go with these networks.
Greets!
GM
OK I will look into the Olsen cabinet tonight.
I might be jumping ahead here, but will I be ending up with a 17 cu' cabinet or be prepping for a 27 cu' ? Size will not be a restriction for this project, but if there is diminishing returns beyond 17 cu' 30 Hz? How much lower would the additional 10 cu' go?
I will measure the specs. I don't think they were abused too bad. I think I am the 2nd/3rd owner as I bought them from the original owners son, possibly grandson.
They came in Valencia cabinets, along with the matching center console which had a Fisher 400 in it.
I thought last weekend that it was a home-built type deal by the way the amp was mounted. It was also hacky where the Garrad was dropped in.I was certain it was DIY which was good as I really did not want the cabinetry.
Well this morning I stumbled across the center console and speaker cabs in an unrelated image search lol. I had already tossed it, but a co-worker decided he wanted it. I'm over it now but I definatly wasn't looking to scrap anything Altec.
I won't be tossing the speaker cabinets now though. lol.
So aside from a recent Halloween party, I don't think the speakers have been used and abused all that much, but this is speculatively based on information from time of purchase.
I downloaded alpha and beta, but only installed alpha. Thank you for the links, I will find the tutorials helpful.
OP,
Is the GPA and the Altec vintage product the same thing? Which one you have...
(I would guess you have the new one.)
http://www.dvq.com/hifi/images/604e.pdf
http://www.greatplainsaudio.com/downloads/604E Series II Spec Sheet.pdf
Vintage version, I am not yet fully aware of the nuances between the two other then maybe the efficiency and surround composition.
Regards ~ AB
No, but that is a good idea, however I think "SNR" was too short. My user name is "HighFy". If it could be SNR, that would be great. Thanks.
I am going to pop open the cabinets tonight as I only briefly look in the back of one them when I bought them.
Thanks for all the enthusiasm, I assure you it is mutual.
GM
Joined 2003
Hmm, I see I could have phrased that a bit better…………….I just meant that his his idea of a home high sound quality system circa 1950, which included a large, tall cab with tapered back baffle, driver at the top to get it up to average ear height with a ‘critically’ damped vent at the bottom showed me a better way to do vented alignments.
Since it’s ‘only’ ~8 ft^3 tuned to ~75 Hz to suit his RCA drivers, it would only be a good one for the earliest duplexes without re-tuning as by 1950 Altec was using 8 ft^3/45 Hz alignments, though in a standard ‘lowboy’ reflex.
Until you have measured them and told us the particulars of your set-up, i.e. room details, planned speaker/listening position, electronics, not much point in speculating about cab size, especially since you want to do it with no EQ.
In both the huge 604 alignments, they were Vb = Vas, Fb = Fs and driven by matching impedance amps, which effectively raised the driver’s Qts almost 2x, ‘filling’ the cab to a ~maximally flat alignment, so they each had virtually the same amount of bass, just the smaller cab has a lower efficiency.
A lot will depend on the amp used and how close to a wall, corner they will be. Most folks I’ve done cabs for regardless of brand, model usually build as big as they can ‘afford’ to maximize tuning flexibility, then use some form of EQ to balance them out.
Olson’s ‘MLTL’:
GM
OK I will work on the measurements.
As far as particulars, the room is ~12 x 20 with the speakers on the 12' wall. This of course may change so I would rather have not have too room specific. That being said, I have always typically had speakers in a similar arrangement, which has the speakers in the corners kinda toed in a bit.
This puts me in the near field about 4'-6' away from each speaker. I am not so concerned with how it fills the room so much as the near field where I will be enjoying it 95% of the time.
They will be used in similar domestic situations in the future as well.
I have pondered corner-back cabinets, but in reality I can still place rectangle cabinets in the corners so I had not planned on corner cabinets although upon reflection I have not ruled it out.
Amplification will be primarily be SET 2A3 or on occasion SE 6BQ5, basically in the 2-5 watt range.
Since you are able to measure the driver and are open to EQ, consider Linkwitz transform to solve your big box quandry. The new GPA version of 604E has power rating of 100W, I don't know what the original's max power was, but even 50W will allow enough EQ to at least duplicate the sound of a Qtc .5 box (Vb=Vas) in a Qtc .7 (or maybe even Qtc 1) sized box. A small box is easier to brace and damp so far less box noise, better WAF, no reflex port distortion, etc.
More: TA Speaker Topics - Designing a Linkwitz Transform
Linkwitz Transform Subwoofer Equaliser
2A3 may not be enough power for bass EQ, but SET damping isn't best for clean bass either. Weigh the pros/cons. :)
it sounds very good in the original Karlson but may not go "low" enough for your tastes - the sound is strong, vibrant - don't use any baffle step comp. in the xover.
The Karlson is an interesting consideration, although not quite what I am after, as you say if they are not quite low enough.
They are also a little too low physically, as I would like to get the horn higher off of the floor.
Actually I did not want to EQ much at all if possible.
The Altec 604E is a 35watt.
Honestly I had not even considered a response suggestion something like the Linkwitz, it almost sounds sacrilegious lol.
I would prefer to put the efforts into the mechanical construction of the box rather then electronic compensation devices.
Are you suggesting putting them in a small sealed enclosure?
WAF is not on the radar at this point in time, bring on the appliance sized speakers.
I've often wondered if these 'old school' duplexes would retain their 'tone'/'open' sound if stuck in a box just big enough to enclose it and LRT it flat to at least 40 Hz and use digital EQ to lower the horn for use as a small room/near-field monitor, but I'm guessing at such a low efficiency that it would just sound flat/lifeless as a billiard table.
GM
Ya I don't think it would sound too great, at least on my end
I was literalyjust playing with some digital EQ as I type this in their ~5 cu' Valencia enclosures.
There is no comparison to just letting them rip. So far any slight adjustment to the low end just makes em sound like normal-ish speakers. Adding any bass seems to "shrink" the sound of the higher frequencies, for lack of a better description.
I am smittened with the setup so far, just want give the lower frequencies room to breath so to speak.
Having just experienced Stella by Starlight both ways, I want to maintain that midrange.
I don't even care much for the L-pad on the horn at the moment, although to be fair it needs to be cleaned.
That being said, it this current configuration they sound unbalanced, favoring the top end.
Then ‘BIB’ [bigger is better] it is!
Ooh! Way too much ‘shout’ for me, but to each his own.
BTW, what is your amp's output impedance [DF]? Not tap rating.
GM
I will measure the 6BQ5 amp, what frequency would be most relevant? say 30 or 60 Hz?
The thing is this will likely not be the amplifier used
My SET is under construction, but will be some sort of direct-coupled variant.
I had not considered building this around on specific amplifier, but I suppose that is an option. I don't know if that helps much. lol sorry.
GM
Are you saying the big box is still going to shout, or are you referring to my current small boxes?
Here are a few pictures of one side.
It is a little scary removing it from the baffle as I was worried about the surround goop sticking to the baffle. There was a small section, but everything came off OK and intact.
Fingers crossed for the second side.
I just finished cleaning the pots with acetone in the crossovers.
It wasn't necessary to open the pots, I just put some acetone in a little dish and just submerged the pot itself. I thought I would try that before taking them apart, as they don't always seem to go back together as nice.
If I didn't know any better I would say the speakers might even sound a little better.
Also the wire terminals on the speakers were barely holding on to the wire, they are snugged up now.
I was able to remove the scratchiness from the pots, however one of the pots has a crack through the phenolic wafer. I'm assuming it's a rheostat type of pot with a wound wire track. At least it feels that way on the broken one and it is somewhat functional still.
I will look for some replacements or perhaps hard wire in some resistors. No biggy.
The second speaker had a much bigger glob of dope stuck to the baffle. I took my time and was able to remove it without incident. I put down some green painters tape on the baffle were the dope contacts to aid in future removal.
I also flipped them over.
As you can see in the above pictures the crossovers are potted, but I don't think there are electrolytics in there so I am not so worried about recapping I guess.
Just to clarify I have been calling my cabinets Valencia, more accurately they are a "Flamenco" cabinet which typically housed a separate woofer and horn.
