815 amp
Sorry, I hate to brag... OK, maybe I don't 😀
Here's the 815 AB2 amp on the breadboard. THD at 1W <0.02%, and 40W out at 5%.
Two tubes, a 6AC10 and an 815. Plus a little silicon.
Details and schematics to come...
Pete
A few details:
B+ = 470V, G2 = 125V, pretty close to the published operating point for the 815 in AB2, about 22mA per plate at idle. ~8k plate-to-plate load (using a 4.3k xfmr with 8 ohms on the 4 ohm tap).
The driver is simple, a gain stage and a diff amp, a resistor tail to a -95V bias supply.
There is global feedback from the OPT secondary to the cathode of the input tube.
Freq response using a Dynaclone A431S is down 0.05dB @ 20Hz and 0.02dB @ 20kHz, -3dB @ 75kHz (at 1W). Zo ~ 1.6 ohms.
Pete
Cool, thanks for the numbers and other details, and web pages. Lots for me to learn from and get my 815s cranking. The bit with 8 ohms on the 4 ohm tap to double output resistance is new to me, interesting approach.
Garth
Mr. and Mrs. Potatohead are alive!
Got the two amps assembled. A tad over 50W out on the 8 ohm tap...
I will be documenting things soon, but basically it hasn't changed since the last schematic I posted.
Pete
Yes, there is a "ground breaker" consisting of 2 series back-to-back silicon diodes between ground and chassis / AC line ground.
There is also one little error that I fixed after taking the photo. The green wire headed to the power transformer is the filament CT. In the photo it is connected to chassis / AC line ground - it is supposed to be connected to ground, not the chassis.
Pete
Well, sure but where I come from I cannot get a hold of the exact components used by Pete and I would like to be faithful as possible to the original design...
with an excel BOM I can order from Mouser and be sure to get the right parts (shipping and VAT are expensive here so if I order I need to be careful to get everything I need).
