I think I make the VARs a beating then. I need more then two, anyone knows a place that gives good multi discount?
If you make the decision, trust me, we will find something you like!
My veranda is 20 meters from the beach. We can have some bloody marys together and listen to some music!
As a divorced 5050 father I dont really get so far atm. But I could use a summer estate. Maybe something up in the hills?
You can get something in the hills, but we can have some drinks at my place😉
You are welcome anytime.
Just asked Benz guys about their opinion. I can up the gain to 65 dB on my phono, but that still leaves me guessing. Will there be enough gain with a 0.4mV cartridge in my whole chain dynamics wise.
My Benz LP (0.28mV) works fine with 58dB phono stage gain. Of course, your preamp gain is relevant too - mine has 11dB of gain.
Andy
andyr;3923611 your preamp gain is relevant too [/QUOTE said:and the amp gain, and the speaker sensitivity 🙂
My preamp is a buffer – DCB1.
Curious, what's your total gain structure and what's your system?
(One day I will be punished for being on constant off topic.)
Aah, OK, a passive preamp - then, yes, I suggest you will need more than 58dB gain in the phono stage.
Just as an example:
* with 55dB gain in the phono stage
* and with my last preamp - which had only 6db gain,
... I didn't quite get the volume I wanted, when the volume control was fully clockwise. Whereas when I moved to my new preamp, its 11dB of gain is plenty - so I no longer need to turn up the preamp to max.
Speakers are Maggies - very low efficiency (83-84dB); amp has 28dB of gain.
Andy
i have grown fond of Ohmite Wn series. 20ppm Non-I
I saw those recently and thought they looked interesting (like, maybe they could be rhopoint oem?). Where are you using them in the circuit, Buzz?
The biggest supplyer of VARs seems to be Partsconnexion Vishay VAR-Series "naked" Z-FOIL RESISTOR
Digikey seems to have 3 sizes https://www.digikey.com/product-highlights/us/en/vishay-precision-z-foil-var-resistor/310
Then it is Hificollective that sells CARs Charcroft Z-Foil Resistors for Audio homepage. Does those hold the same qualities? Anyone knows other sources?
I use them as the 1.5K power resistor dividing the current of the folded stage. I have used them as source resistors in both power amp and preamp builds and will be using them in the signal path in my rebuild of the Salas 6v6 preamp. I think you have to go to a 5ppm SMD(Vishay TNPU or Susumu RG) or the Naked Vishay's to see much improvement, but you do so at a large multiple of the price. Is it audible? At this range it is getting tough to discern and the build has to be executed very well to appreciate the subtle differences.
Looks like Charcroft had Vishay make some "special order" resistors for them and just rebranded.
I buy them direct from TEXAS COMPONENTS
Contact Ms. Janet Alcebo - jalcebo@texascomponents.com - she will send you an invoice and you can pay through PAYPAL.
Takes about two weeks for them to make what you want. You can get any value you desire and the price is a little better than any of those other folks will charge you.
The CHARCROFT must be the same thing - sure look the same. I am sure Ms. Alcebo would tell you if there is any difference.
I've just tested my PSU built with the GB PCB and using Hammond 229D34 transformers with 2x17V secondaries. My mains voltage is exactly 230V but for some reason (the 15% regulation perhaps) the transformers put out 39VAC which ends up as 52.5VDC unloaded at the DC outputs. Is that voltage safe to feed the Folded with or do I need to lower it and if so what would be the easiest way to do that?
Use 500 Ohm 10W resistor (or any combo like 1k//1k 10W) as dummy load so to create ~100mA draw to see how low your raw DC will go when loaded before you apply the real load (phono). Better safe than sorry. That way you can adjust the dropping resistors on the PSU board higher if the raw level stays uncomfortably high. Don't touch the dummy load and don't lay it against plastic surface etc. its gonna go hot.
Thanks Salas. I had to eBay some cheap 10W resistors before I could try this out. So, with 1R dropping resistors and the 500R dummy load I'm getting 49.5V/50.2V. I'm guessing I will have to increase the value of the dropping resistors then?
Yes, better keep the raw voltage at 47-48V DC to avoid stressing plateaus due to possible high mains hours. But its not a pressing issue since you are at ~50V already. You are safe enough now.
Thanks for your help. I don't have any suitable resistors on hand so I'll settle with the slightly high voltage. Now I'll get going with the boring metal work for the chassis. Not exactly looking forward to making the panel holes for the XLR connectors with a hand drill and no large enough drill bits 🙂
- Analogue Source
- Simplistic NJFET RIAA
