Lets get this straight Mr. Wurcer.
Are you claiming your AD797 uses input bias current cancellation? The AD Datasheet implies not and IIRC so did my Jurassic tests.
Sorry yes, simply a misunderstanding on your part. We engineers are clever little b*****s.
No, not needed due to the low IB 😉 Never had any issues with it 🙂
http://www.analog.com/static/imported-files/data_sheets/OP27.pdf I didn't use the RIAA circuit in Fig 41, but designed my own.
You said 5534 in your post. That's got 200 nA typical and 1uA max. I consider that too high.
The LM4562 Ib is quoted as 10 nA typical. I wondered how they got this so low - I assume they are using Ib canceling techniques then as well.
@ kgrlee
My OP27GP/37GP's are Analog Devices from Farnell
No i said "That's what i did when i designed the RIAA stage of my PreAmp with OP27's many moons ago" Referring to what krglee also did with 5534's
Gasp! Shock! Horror!Sorry yes, simply a misunderstanding on your part. We engineers are clever little b*****s.
AD datasheet speak with forked tongue! 😱
Surely its usual to denote an input bias current that could be either +ve or -ve as +/-50nA as on the LT1115 datasheet?
AD797 input bias spec (in da evil false datasheet) at 500nA to 3uA is also as large as several OPAs without input bias cancelling.
I'm still reeling in shock. Good think I never put anything with AD797 into production based on my limited tests. 🙂
Yes - I stand corrected.
I would still not connect the cart directly to the input of a 5534. You can use a really high quality film cap for the job because the Zin can be 47k.
Here is the opamp noise visualizer spread (Excel)
Opamp Noise Visualizer | hifisonix.com
The AD797, LME49990 and LT1115 are the best so far for <2k Ohms.
Are we missing any others? Have a go an post up your results here!
scott, i couldn't resist.
this made me laugh coke through my nose.
haven't done that since jocko and fred days ...
mlloyd1
mlloyd1
LME49710, -720, and -740. LME49880. LME49990. They're all solid performers. Personally, I prefer the LME49700-series.
~Tom
~Tom
There are better FET input opamp these days than OPA132, OPA134 from TI.
OPA1641 and OPA140, for example.
Close to OPA627 specs but do not cost a fortune.
Patrick
Patrick
I plugged the OPA627 into the 'visualizer' and it is very good above about 250 Ohms - so its the champion above this Rsource so far (ref 1 kHz). But, the 1/f noise seems to start quite high, so you would need to watch out for that in RIAA applications.
not at all - look at my graph, the AD743/745 is plotted along with the OPA627
for either the i_n is no problem below 100s of kOhm
and I already mentioned paralleling the 4 op amps in the quad OPA1644 - which would then better even the AD743 - and take up less space if you can deal with tssop
> I already mentioned paralleling the 4 op amps in the quad OPA1644 ...
Couldn't agree more.
Patrick
Patrick
Show what your LN uber OPA can do
There's loadsa stuff that is more important for LN design than choosing the latest uber OPA from their Datasheets.
At the risk of hijacking this thread, who wants to show a real life application circuit that gets within 1dB of AD797's 1nV/rt(Hz) using it or some other uber OPA?
You can specify the application etc but the circuit must include ALL the stuff for the practical application.
Detailed noise analysis please.
Real measured data preferred but fully worked out flights of fancy allowed if detailed analysis provided.
Guru Wurcer, you can't enter cos you're the judge.
We do expect you to show us how it should be done after you've awarded the prize .. which is a glass of Guru Wurcer's finest Burgundy if the winner is ever lucky enough to visit him.
BTW, the most important things I've got out of this thread is the realization that
- even AD datasheets can lie. 😱
- AD797 has evil input bias compensation
- and I must now find a 1nV/rtHz OPA to replace it in my Bumper Book of Supa Dupa OPAs 😡
Patrick
OPA4140 in multiples, with cross-correlation, are being used by physicists to study low frequency semiconductor noise. I simulated their results in TINA down to 0.010Hz and the devices really work well for instrumentation/measurement.
I am only taking the data from the data sheet jcx - worst case at 1k Ohms. I think you are plotting 1/f. I am plotting nV/rt Hz.
OPA4140 has the same footprint as OPA1644.
In fact, the two parts are almost identical in spec except for bandwidth ?
Patrick
Patrick
Just to demonstrate it is possible to parallel an OPA1644 TSSOP within a DIP8 footprint (10x10mm).
Each opamp has its own 0603 SMD output resistor (say 3.9R).
Patrick
Before you get too enthusiastic, check figure 10 on datasheet. Looks like bad non-linear input C. In fact bad at rsource = 600 Ohms I find hard to believe. Extrapolate to 47K for 4 in parallel !!.
- Low Noise opamps for 2014?
