I'm making some audio opamp circuits, some LPF (for subwoofers), some summing amp circuit, etc.
Usually I go for TL072 and NE5532, but I was wondering, what opamps do you use nowadays?
I'm looking for low noise, decent slew rate, and not exaggerated bandwidth. And most important of all: sane price. No $25 opamps for a silly audio filter!
OPA2134...They look nice...
These are also pretty nice:
http://www.ti.com/lit/ds/symlink/lme49720.pdf
although I'm not sure...the 50 MHz bandwidth might be wide enough to make you uncomfortable...
That's why I didn't mention it. It's hard to beat when used wisely, but it MUST be used wisely.
Mike
LM4562NA it is also similar I think 🙂
try the LM4562HA too that somebody says it is superb...
with high performance opamp the PSU & decoupling caps should be wise too.
I read again post #1, but for "only" low frequency/LPF NE5532, LM833 or other bipolar type input maybe sound not so different...
You can try it by yourself, you can have fun to try bipolar type opamp & compare it to jfet type for your LPF... lets start with NE5532 vs TL072 😀
some expensive opamp need better PSU too, to sound at it best
I don't know if it's a problem for you but the AD8599 is only available in surface mount. It does look like a descent one for audio.
Mike
Mike
i saw LT3032some expensive opamp need better PSU too, to sound at it best
ultralow noise dual regulator... only 150mA though. but 20uV noise! and +/- in a single IC
OPA 2132/2134
LM4562/LME49720
LT1124
LME49xxx is mentioned a lotOPA 2132/2134
LM4562/LME49720
LT1124
let's go all the way up to LME49990! so many 9s! that MUST be the top of the line, no?
Ultra low noise, ultra low distortion. From the Overture E-series.
Overture as in LM3886? 😀
OPA627 (Burr-Brown)
Noise - 4.5nV/√Hz at 10kHz
OPA627 datasheet pdf datenblatt - Burr-Brown Corporation - Precision High-Speed Difet OPERATIONAL AMPLIFIERS ::: ALLDATASHEET :::
I use them in active subsonic filter - top notch performance.
Rather expensive though.
that's cheating! we said no $25 opamps. that one is $25! 😛OPA627 (Burr-Brown)
Do you have an O-scope that has at least 50 MHz bandwidth? Pretty much mandatory when using those LM4562 class devices, or any high speed opamp really.
Mike
Mike
Ah, sorry - did not actually notice that condition right away 🙂
Yeah, that's the only downside of this opamp ((
In my case, on one hand, it's a silly audio filter, cutting some ultra-low frequencies, on the other hand, it passes everything else. In 7 channels. It has to pass it perfectly 😉
I am very found of the LT stuff, To many to list!!!
Also besides TI's LMExxx's the OPA1664 has pretty impressive specs as well.
jer 🙂
jer 🙂
What about Audio - Audio Operational Amplifier - LME49880 - TI.com and Audio - Audio Operational Amplifier - LME49710 - TI.com, I have been using them in a RIAA amp and it sounds very nice (also MC). See also http://www.diyaudio.com/forums/analogue-source/165603-balanced-input-all-dc-coupled-riaa-preamp.html
OPA627 (Burr-Brown)
4.5nV/Hz is not very good, I think you are better of using one of the LME's
LME49880 - 7nV/√Hz
Does not matter - both are very low
Wow didn't know opamps get that expensive.
In my country OPA627BP cost 76.32 USDollars each if you include VAT tax.
Lol now I guess I'll never know how they sound in a preamp 🙂
I purchased them for $30 each. 3 pieces per channel x 7 channels = 21 piece.
I know, I'm crazy 😀 But I'm a skydiver anyway, so... no surprise 😛
Here is the link to my design:
Bloody expensive 7-channel Subsonic filter
5-th order Chebyshev
They sound very good
- Low Noise opamps for 2014?
