Low cost ES9018 DAC board GB
PayPal paid for pr TPS regs to order
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
3) richard_pc - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, 2 TPS regs (Unsoldered) - PAID
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
9) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
10) rredline - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
11) DaveK - 1 or 2 kits
12)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered
13)Turbon - 1 PCB, 1 ES9018K2M + 1 oscillator + 2 TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
14)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
15)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
16)vuki - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
17)number9 - 1 PCB, 1 ES9018K2M+oscillator + TPS regs (pre-soldered) - PAID
18)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
19)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
20)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
21)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered) - PAID
22) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 oscillator (both pre-soldered)
5) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, TPS regs (all pre-soldered) - PAID
Corrected my order. Thanks.
3) richard_pc - 1 PCB, 1 ES9018K2M + 1 Crystek 950 + TPS(ALL pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered) + Crystek 950+ 2 TPS regs- PAID
Update my order as paid with Crystek and TPS reg.
Quan
22) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 XG1000 oscillator (both pre-soldered) - PAID
16)vuki - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
22) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 XG1000 oscillator (both pre-soldered) - PAID[/QUOTE]
order corrected
13)Turbon - 1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
order corrected 🙂
Those who haven't paid still kindly pay up quickly.
Sent from my Q700i using Tapatalk
4) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, TPS regs (all pre-soldered) - PAID
5) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
6) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
7) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
8) rredline - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
9)Turbon - 1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
10)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
11)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
12)vuki - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
13)number9 - 1 PCB, 1 ES9018K2M+oscillator + TPS regs (pre-soldered) - PAID
14)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
15)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered) - PAID
16) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 XG1000 oscillator (both pre-soldered) - PAID
17) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
18) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
19) DaveK - 1 or 2 kits
20)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered
21)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
22)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
Please note that only 9 boards are available now, i will not take payments after the 9 boards left are booked.
Thanks Syl..
One query..
This PCB has 1 USB IN (to hook it to PC) and 3 SPDIF IN for Audio in and provides RCA out (for Left and Right channels). Is my understanding correct that the schematic and parts list you published will enable all these options?
It does not have USB interface. It does have 3 SPDIF IN and audio out. The schematic and part list will not enable all options. All options can be enabled only with an mcu. It also works without an MCU with default settings with one spdif, I2S/DSD with auto detection.
17) mrsavage - 2 PCB, 2 ES9018K2M (pre-soldered) - PAID
18) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
List updated
