LF 41Hz AMP10 Basic assembly instructions
Hi all 🙂
I ordered and received an AMP10BASIC (41Hz Audio:AMP10-BASIC kit) from 41Hz Audio. It arrived in good time, but the forums are STILL down and I can't access the build instructions.
Several emails to the store owner have gone unanswered (but that seems to be the norm having done some searching).
Can anybody help out with instructions? I'm not confident enough to solder it based solely on the schematic.
Many thanks!
Here You go.
I strongly suggest You modify the 5V according to the included circuit.
Also change c60 to a larger value (I used 470uF) and I recommend You use a input gain of 1.0 (22K for R3, R4, R43 & R44).
Good luck with Your build!
  • Amp10B Ai.pdf
    Amp10B Ai.pdf
Duh now that I think about it and see how a bridge rectifier works, that makes perfect sense >_<.
What I think I know:
The amp design calls for + and - DC. The rectifier polarities are swapped on the board (i.e. the + pin is ground on one rectifier, and the - on the other one). It is this that creates the + and - DC supplies (which are then filtered by caps). Am I on the right track?
@xrayspecs Sorry to hi-jack the thread - but re: the Amp10 Basic and the Muting/Relay and the instructions:
I previously modified by Amp10 Basic to follow the altered directions in the PDF - it's possible I did something wrong, but basically with my 18VAC transformer something didn't quite work properly and I ended up spectacularly nuking a TA2022 and melting a few traces off the board (between the bridge rectifier and the big resistor R100 next to the LM317). I managed to replace the TA2022 and repair the traces - and it seems to work - though I'd love to have the speaker muting work properly.
Pic: https://lh5.googleusercontent.com/-...ZRRJDqI/w1125-h844-no/IMG_20130127_202205.jpg - I cut the chip off with side cutters, hence the mess.
Does the modified +5v circuit you've provided totally replace the existing LM317 (which I think is also in your picture?) or work along side it?
Is it discussed anywhere else - I'd love to get some more detail so I can understand what it changes. Should it be done in conjunction with the changes to the time delay resistor R2?
The R2/C60 modification is made to adjust the turn-on delay.
The LM317 (and the 2 resistors) replaces R100 but is used in conjunction (cascade-coupling) with the original regulator. This is done to keep the 5V from collapsing to early during shut-down and thereby producing problems with the turn-off protection.
An added benefit is the better regulated 5V 🙂
Hope this helps.
