Demian,
Somewhere on this thread or in another we had this discussion with Sy and if I remember that correctly he stated there are no plasticizers added to the material in an album. There were no materials to leach out of the materials used, especially by a water reaction. Only thing the water would do is leave mineral deposits if it was not DI water.
I don't think I said that about LPs- there's certainly plasticizers in their PVC compound. I did say that there isn't an external mold release used in the process, which may be what you're remembering.
Water will not leach out carbon, but it might leach out other things in the PVC compound. And yes, unless the water is insanely pure, it will leave behind some residue. I have an experiment in mind...
Thank you SY.
I like the deceleration method. 😉
But you need to know the inertia of the total rotational system rather accurately.
Patrick
See this one:
Turntable Forum • Shure V15Vx + JICO SAS antiskate measurements ± brush
If there is anything to come out of measuring record alone vs record with cartridge running on it, it is necessary to take a number of measurements –at least 5- and average the results.
And have the platter rotate more than half an hour before starting the measurements.
George
> Would it not be possible to calculate the energy from the friction of the needle over the vinyl? We know dimensions of the tip, tip force, tracking speed ...?
There is a simpler way Jan. 😉
Just measure the increase in current of the turntable motor.
Multiply by the voltage, then you have the value you want.
Patrick
But that only gives total loss, and besides likely being a difficult small difference of large thing to measure.
jn
Is this the result of your measurements?
For Scott and anyone else interested in rumble (and rev velocity stability) measurement without using the 3150Hz track of a test record. Pages 16-18:
http://www.americanradiohistory.com/Archive-DB-Magazine/60s/DB-1968-03.pdf
A lot of -now- lost knowledge regarding tape/disk recording technology can be found in these archives.🙂
George
jn
George
No. It's one of my excel spreadsheets, culled from online data available at mws wire.
I first made a sheet from the gauge to mm chart page 31, then calculated the cross sectional area from the inches diameter, then inverted to get a scaled resistance, then divided that by 114 to get to the actual conductor per foot resistance. I then verified that it matched very closely the gauge to resistance values specified on page 4.
I tried several things to get the 1/0 through 5/0 to work on the spreadsheet, but it kept doing very weird things. I suspect it is because I assigned negative numbers to the oughts for the graph...-1 for 1/0, -2 for 2/0, etc (I was proud of thinking that up, until the graph puked on me..). Even though the y axis is logarithmic and the x axis linear, the graph did not behave when I included negative gauges. I suspect the log y axis to be the culprit.
Welcome to MWS Wire Industries
http://www.mwswire.com/pdf_files/mws_tech_book/page31.pdf
http://www.mwswire.com/pdf_files/mws_tech_book/page4.pdf
ps.. I did this a while ago to calculate the pulse ampacity of small copper wires in a liquid helium environment, when subjected to a high current pulse with a time constant. While large guage wires are best for 200-400 amp pulses running a decay constant of 4 or 5 seconds, they conduct heat from the cold to room temp.(edit:the fridge consumes 1000 watts for every watt of heat loss at 4K, 2000 watts per watt at 1.8K, so heat loss through overly large wire gauge is a major concern) It required also the heat capacity and conductivity of copper from room to 4K. Turns out a 24 gauge wire can survive a 400 amp 4 second time constant pulse easily, and it won't exceed room temp.
jn
Sy and George thanks for the information, sorry I mis-remembered the plasticizer information. Sy, from what I have observed the internal mold releases continue to leach to the surface of a molded plastic compound long after molding. Most of the compounds I am familiar with were some form of synthetic micro-crystalline waxes that were not part of the polymer matrix, but were just in suspension within the polymer compound. If this is the same in a pvc material how would that change the surface of the material over time? I would think that the surface tension of the material would change or the lubricity would modulate depending on time and temperature?
Thanks jn
Logarithm of a number x<0 is undefined, so the spreadsheet gets mad or refuses to accept your trick 😉
I know. I kept the x axis linear scale so it could go negative thinking that gee, it's only a straight line, why can't it figger it outs???? It worked great on my screen, the felt tip pen writing on the screen looked perfect..😉
I'll check out the litz thing, thanks.. I just finished assembling 360 coils using honkin high count litz and I suspect there will be more.
edit: they only go down to 18 gauge??? All my coils were 15 gauge equiv..
We used Cooners. They go down to 2AWG in type 5 litz. We used a bunch of that about 10 years ago for a neat magnet. I just used 15 gauge type 3 for my coils.
http://www.coonerwire.com/litz-wire/
Holy mackerel, type 6 goes up to 525 KCMIL!!! That's about an inch diameter, 21 thousand strands of #36. All my speaker cable needs have finally been addressed!!!!
Let's do a group order right now!!
jn
jn
One of our guys set up a demo for current measurement in e-cars. He used some new copper-clad aluminum mutistrand, you can jump rope with #0. The battery was simulated with a 12,000F supercap, impressive, you can draw a spark with only 50mV charge!
