Even harmonics acclaimed in the tube amp. Multi-diode Type 47 can be very very good to express it.
This tube amp I just do, I can hardly believe that he would have such a wonderful harmonics.
Lamented nearly 100 years ago, humans have made such a wonderful thing.
Direct thermal coefficient higher harmonics antique pipe sounds overtone Miaomiao have the feeling linger three days.
ef12 is a very well-known audio control, beyond the reach of today already. Unlike modern engraved antique pipe tube, you can always produce, its price is also expensive, 58H of the output transformer, so it is also far higher than the 2A3 output 20H cattle around a lot of difficulty. But I still think it is worth it.
Over 65 years-old age fans called "Ma Jingquan" as I made the output transformer. Here I would like to express my deep gratitude to him.
I see nothing revolutionary about the design of this integrated amplifier. That does not mean it isn't good sounding, but that it is identical to pretty much every other one I have seen in the past few years coming out of China. As to even ordered harmonics, solid state can also be predominantly second ordered. It's entirely about design goals.
Dig the EF12. This looks like advertising though.
EF12 = overpriced EF86 in a metal jacket
EF12 is a glass enclosure.
The 47, according to the schematics is a pentode, not a multi diode
And why use the 2X 10R resistors at the cathode, when there is a centertap on the filament winding on the power transformer?
google translate misunderstanding caused.
If you do not have that two 10 ohm resistor, you have any good suggestions?
See beautifully diy produced, that it is the advertising, somewhat narrow.
Oh, you made this yourself?
- Tubes / Valves
- Extraordinary harmonics. Type 47 # tube amp.
