So, if Russia is slapped with a trade embargo, what happens to our suppliers of Russian made tubes? Does anyone think this could happen?
How about adapting subminis?
6AL5 submini substitute - AudioKarma.org Home Audio Stereo Discussion Forums
Also see:
Seduced by the Pure Music of Virgin Commies
(written before the fall of the Soviet Union)
http://antiquesci.50webs.com/VirginCommies.htm
Also see:
Russian valves will still find theie way into the US......... the is no trade embargo planned like in Cuba.
There is also no reason for supplies to "dy up " if there is still world wide demand for them.
The same can be applied to the great Russian vodka. 🙂.
How do 6BG6s sound as output tubes?
Antique Radio Forums • View topic - 6L6 vs the 6BG6
I don't have a clue "how they sound". If it sounds like "something" then there's probably something wrong somewhere. It appears to be the same as a 6L6 but with a different pinout.
I found a strange patent while searching for 6BG6 references.
https://www.google.com/patents/US2640173
A magnet is held close to the tube to affect the electron beam. Getting tubes too close to magnets usually isn't recommended because they can magnetize the parts. Maybe a magnetic field can be used to reduce distortion and start a new tube craze.
The internals of vacuum tubes are made from pure nickel, a magnetic material. As such, the are sensitive to EMI and should be protected from all sources. Hanging tubes out in the air like they are some kind of laundry is a bad practice in my opinion.
General Radio, the great grand daddy of test gear, made a noise source that was a particular vacuum tube placed between two strong magnets. I used to have one a long time ago.
This song
Love - 7 And 7 Is - YouTube
is on this album
Nuggets, Vol. 9: Acid Rock - Wikipedia, the free encyclopedia
which I used to listen to years ago using a stereo 2 stage EF86/6267 preamp with National (USSR) EF86/6267 tubes. I like the way it sounded in a long room in my house which has a lot of wood paneling and curtains on 3 sides (over windows). I found the schematic in an old magazine (Audio?) and I believe its the same as or similar to the Mullard preamp here http://bottlepreamp.blogspot.com/ . I only put in two equalization networks in mine, one for a turntable and one for a tape head.
is on this album
- Member Areas
- The Lounge
- Russian tubes bye bye?
