T/S parameters of ATC Bass drivers
It seems that your computer cannot establish a direct secure connection with the Dropbox servers. Could be the NSA listening in on you ( 😛 ) or a proxy.
I have attached it in zip form below; hope that helps.
With Google Chrome, who knows? for years I used Mozilla Firefox, but a couple of years ago it began causing the computer's processor to run at 100%, effectively locking it up and none of its updates has solved the problem nor did uninstalling/re-installing it.
Thanks, appreciate it!
GM
edit: FWIW here's the link to these mostly incomplete sets of specs: http://www.atcloudspeakers.co.uk/wp-content/uploads/2014/01/ATC-Driver-Specs.pdf
No - it is the driver for bass midrange used in the SCM20 from ATC - go to
ATC SB75-150 SL midbass then?? (SL - super linear).
AudioStereo -- ATC -- Technology
http://www.diyaudio.com/forums/swap-meet/224538-atc-sm75-150-not-s-repair-kits-sb75-150sl.html
Note: sure it doesn't look like it (besides the lettering stating "SCM20sl"), compare the two. It has a round/circular flange around and something black on top like a waveguide??? 🙁
http://www.diyaudio.com/forums/atta...drivers-atc-scm20sl-chassis.jpg-side-view.jpg
